Temp gauge incorrect
Old Mar 26, 2006 | 07:02 PM
McLeod's Avatar
McLeod
I have a '67 Bronco w/ 351W that I have installed new VDO gauges. This has been a non running project that has been pieced together with many other Broncos,(most years are very similar), so I do not have a "before" to reference to.
The problem is the temp gauge is reading correctly when in the KEY ON ENGINE OFF and when in ACCESSORY , but when the engine is started and running, the temp gauge immediately maxes out.
The gauges are new and I have used the sending unit supplied with the gauges.
It must be grounding out when the engine starts somehow. Any ideas on where to look???
Regards
Ken
Old Mar 27, 2006 | 07:13 AM
tjc transport's Avatar
tjc transport
i ain't rite
disconnect the wire from the sender, and see if it still shorts out. if it does, it is in the wiring. if not it is in the sender.
are you using the original wiring, or did you run new wires?
Old Mar 27, 2006 | 09:26 PM
Dealford's Avatar
Dealford
And of course the engine has at least one ground strap to the body, right?
AL.
Old Mar 27, 2006 | 11:03 PM
McLeod's Avatar
McLeod
You know, after sleeping on it, I came to the same ideas you just mentioned.
No, I never installed a ground to the body. This is the first thing I'm doing this weekend.
I used the original red/white wire. I think if the body ground doesn't improve the reading, I will run a brand new wire to the sending unit.
When I disconnect the sender, the gauge pegs left (cooler). When I hold wire directly to engine block, the gauge pegs right (250deg.)
When cool, the sender has 660 ohms resistance which is near the 700 ohms manufacturer specifications.
Alot of times electricity doesn't make sense, and that is what is throwing me. Sender acts as if grounded out with engine running, but if I kill the engine and return key back to on, the temp gauge is fairly accurate.
Time for some more investigating.
Thanks Guys!
Regards
Ken
Old Mar 28, 2006 | 07:44 AM
tjc transport
i ain't rite
that is a strange one. lets see if i have the facts correct.
koeo, everything is the way it should be. cold engine cold on gauge, hot engine reads proper temp.
koer, wire off sender,gauge reads cold. wire on block, gauge reads overheat, wire on sender gauge reads overheat.
i would try these three steps to try to isolate the problem
replace sender. if that don't fix it,
i would run a wire direct from gauge to sender. if that don't fix it,
run a power wire from battery to gauge.
Old Mar 28, 2006 | 03:23 PM
McLeod's Avatar
McLeod
That is correct.
I won't get a chance to work on it til this weekend, seeing how it has open headers and I don't want to urk the neighbors at night time in order to get engine to temp.
I'll report back with the cause and fix as a follow up when I get there.
Regards
Ken
Old Mar 28, 2006 | 10:54 PM
Bdox's Avatar
Bdox
What kind of ignition set-up are you using?
Old Mar 28, 2006 | 11:27 PM
McLeod's Avatar
McLeod
I just installed a mallory unilite electronic distributor with an ad-on surge protector.
Old Mar 28, 2006 | 11:40 PM
Bdox's Avatar
Bdox
Reason I asked, the gauge seems normal until the ignition is working.
My suggestion would be, get a voltage reading on the power side of the gauge with the key on (when the gauge works normally,) then fire it up and see what the voltage signal looks like that way. If it acts strangely, switch the meter to the AC scale and see if you get a steady reading. My suspicion is that you are getting some feedback from your Mallory unit.
Old Mar 29, 2006 | 08:55 AM
tjc transport
i ain't rite
thats what i was thinking also. thats why i suggested running a power feed off the battery to eliminate that possibility. i just could not think of the proper way to put into words while the painkillers were nice and fresh yesterday.
Old Mar 29, 2006 | 09:19 AM
Franklin2's Avatar
Franklin2
There is a simple test for the gauge. Turn the key to run without starting the engine. Take the wire off the sending unit, and the gauge should read full scale low or high. Then take the sending unit wire and ground it to the engine block. The gauge should read full scale the opposite direction.
If it passes this test, then the wiring and the gauge are ok.
Old Mar 29, 2006 | 09:28 AM
Bdox's Avatar
Bdox
Dave, see post #1. Evidently the gauge and sender are ok, but when the engine starts something is interfering.
Old Mar 29, 2006 | 01:37 PM
Franklin2's Avatar
Franklin2
Yea, his second post says he already did the test anyway. I need to pay more attention.
I wonder if his gauge has two terminals or three?
Old Mar 29, 2006 | 01:41 PM
tjc transport
i ain't rite
dave, blame it on the drugs.
it's worked for me these past 3 months.
Old Mar 29, 2006 | 11:13 PM
McLeod's Avatar
McLeod
It has three terminals.
Here is the schematic. It is wired just as it shows.
https://www.ford-trucks.com/user_gal...id=111828&.jpg
Just as a side note:
All the other gauges work correctly at all times. Wouldn't the ignition screw with all of them if that was a problem?
Regards
Ken
