1970 302
Old Dec 14, 2002 | 05:35 PM
oldfordtruckman's Avatar
oldfordtruckman
I have a 1970 302 that I am having some problems with. When I first start it I have to take the vacuum advance hose off to get it to idle. When I put the vacuum advance off back on it kills it. But I can let it run for awhile and put the hose back on and it doesn't affect it.
Anyone have any ideas what is going on here?
Old Dec 16, 2002 | 11:32 AM
oldfordtruckman
No, ideas on this? Would appreciate any advice.
Old Dec 16, 2002 | 11:49 AM
70f100longbed's Avatar
70f100longbed
1970 302
Make sure the vac hose is connected to PORTED vac not manifold vac. There should be no vac at idle and it should increase as engine speed increases. Connect a vac gauge to the hose to check it. Also set the base timing to about 10-12 deg BTDC with the hose disconnected. Start it up and watch the timing as you rev it up. It should advance a little because of centrifugal advance. Then connect the hose to ported vac and rev it up. It should advance more than before.
Old Dec 16, 2002 | 01:50 PM
mlf72f250's Avatar
mlf72f250
saauvenshine
1947 and Older Ford Trucks
Mar 9, 2015 08:43 PM
GP-TJ
Nov 26, 2011 07:43 PM
jsalty
Sep 13, 2009 07:44 PM
jtravnick
Mar 18, 2005 09:37 PM
Native Gearhead
Aug 30, 2003 12:20 PM
