antifreeze leak
Old Dec 16, 2002 | 08:42 AM
freejay's Avatar
freejay
antifreeze leak
Just thought i'd tell you guys about my surprise the other day. Took my truck for about a 40 minute trip and during that time it developed a pretty fast coolant leak. I couldn't tell where from because it is on the back of the head but it was enough to drip onto the starter, exhaust etc. I had a couple of longer trips to make so i figured it wouldn't hurt to throw some Bar's leak in to try and seal it up, but i didn't expect much. I did that and idled it for about half an hour and it hasnt lost a drop since! Still don't know where the leak was from though...
Old Dec 16, 2002 | 10:49 AM
Huntsman's Avatar
Huntsman
antifreeze leak
[updated:LAST EDITED ON 16-Dec-02 AT 11:50 AM (EST)]Jay it sounds like you may have a freeze plug that needs replacing. They are pretty cheap and you can get an assorted pack of them at most of the auto supply houses. The problem is going to be in having room to remove the old ones and tapping in the new ones. If it is the freeze plugs your repair probably want hold.
Good luck
Old Dec 16, 2002 | 01:38 PM
Sedric's Avatar
Sedric
antifreeze leak
Yeah, I bet it's the freeze plugs. I had to replace one and I plan on replacing all of them this winter.
The problem will be to gain access to them. The one I replaced I had to jack up the engine and support it on a block of wood so I could remove the engine mount. To remove the old plug I drilled a hole in the middle and screwed in a sheet metal screw. I pulled on it with a claw hammer. When it popped out I skinned my knuckles but at least I got it out.
Good luck
Old Dec 16, 2002 | 02:23 PM
pward76's Avatar
pward76
antifreeze leak
Also, be careful that your heatercore doesn't get plugged. I've seen it happen....
Old Dec 16, 2002 | 02:50 PM
1968F250LWB's Avatar
1968F250LWB
antifreeze leak
Kert0307
Feb 28, 2013 07:31 PM
scan7034
Aug 12, 2012 09:25 PM
01raptor
Jul 26, 2012 05:46 AM
tarantulakeeper1
Jan 21, 2012 08:51 PM
wildjon300ci
1978 - 1996 Big Bronco
Nov 9, 2007 04:30 PM
