change oil pan in truck
Yep. Jack the motor (carefully) up just far enough to be able to reach in and unbolt the oil pump, drop (gently) the pump down in the pan, and slide the pan and pump out. Assembly is a pain in the you-know-what, but it can be done. I would recommend replacing the pump. They're cheap, and since you've already got it apart..... DO NOT jack it up on the harmonic balancer. If you've got access to an engine hoist, use it. It's safer, and it will be out of your way. Remember- if you raise the truck, always use jack stands!
jrockdiddy
07-13-2015 08:37 AM
caleballen95
05-21-2014 05:47 PM
pickenspolitics
08-17-2013 07:30 AM
jhaas63
02-03-2013 07:58 PM
robertbourque
01-23-2007 04:38 PM
