Which timing light should I get?
Old Dec 19, 2002 | 02:47 PM
pward76's Avatar
pward76
Ok folks,
I need some advice on tune-up tools. I have a 68 Ranger with a 390 that I want to tune-up and keep in tune. I know that I need a timing light, and probably a tach/dwell meter as well. I have a Pertronix Ignitor module on the way to replace the points.
I know that I don't need the fanciest pro model out there, as I will be an occasional user. So - what would you tool gods recommend?
Thanks!
Old Dec 19, 2002 | 09:42 PM
Mike W's Avatar
Mike W
If you get rid of the points, you won't need the dwell meter. I don't have a specific brand of timing light to recommend. I would spend a little money and get one that clips over the plug wire and is powered by the battery. Some types use a dial and a meter to read the advance. I prefer the plain one that you look at the timing marks to see the actual advance.
Old Dec 19, 2002 | 10:14 PM
Mil1ion's Avatar
Mil1ion
How much money do you want to spend & How long do you want this timing light to last?
Dennis
F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/SigSanta.JPG
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Dec 19, 2002 | 10:22 PM
pward76's Avatar
pward76
[updated:LAST EDITED ON 19-Dec-02 AT 11:22 PM (EST)]>How much money do you want to spend & How long do you want
>Dennis
Well, I saw one that had the tach/dwell readout in the gun for around $70.00> It was at Summint or someone like that. As far as longevity is concerned, I don't want to have to buy more that one
Old Dec 19, 2002 | 10:37 PM
rebocardo's Avatar
rebocardo
I have a timing light from Sears that has held up well to me dropping it from the fender onto the ground a few times. Cost about $30. I prefer the (+)(-)(#1 spark plug) type set up too.
A dwell meter is good to have, it has other uses besides just setting points. I bought one from Autozone for $35, by Actron I think. Good for voltage, dwell, tach. Properly set up you could probably use it to read a EEC-IV system for trouble codes.
I have not seen or tried it, but, NorthernTools.com has a $99 kit that has a digital timing light, vacuum tester, and other things. Seems like a sweet deal. Probably not the highest quality, but, good enough for light use.
Old Dec 20, 2002 | 12:07 AM
geoaigel's Avatar
geoaigel
The Sears brand stuff works okay for timing lights. I have a silver craftsman with an adjustable dial in the back. This is nice to check your total advance at higher rpm. I second that you want solid state ignition. Points are a pain in the neck. I have converted all my points cars to HEI or pertronix.
George
Old Dec 20, 2002 | 12:15 AM
Mil1ion's Avatar
Mil1ion
I would suggest the Inductive Timing Light from Sears.
Possibly the set of Diagnosis Tools.
Dennis
[font color=red]
[/font]
Old Dec 20, 2002 | 09:42 AM
sullyda1's Avatar
sullyda1
I agree with the Sears inductive timing light.
Old Dec 20, 2002 | 11:49 AM
William's Avatar
William
Vacuum gage! Set timing, idle, and trouble shoot all manner of engine malfunctions.
William in Atlanta
Old Dec 20, 2002 | 12:49 PM
1968F250LWB's Avatar
1968F250LWB
