Offroad & 4x4
drop down bracket for dana 60 conversion
Old Mar 25, 2006 | 11:13 PM
fordinmudd's Avatar
fordinmudd
Exclamation drop down bracket for dana 60 conversion
I am taking the Dana 50 off my 250 and putting on a Dana 60 straight axle .I bought that drop down bracket it came with 6 bolts. 3 bolts are shorter and 3 are longer. Do the longer bolts go on the top of the bracket and the shorter ones on the bottom or what?there was no directions to tell me.ugh
Old Mar 25, 2006 | 11:27 PM
fishmanndotcom's Avatar
fishmanndotcom
what drop dpwn bracket are you talking about?
be more specific
-cutts-
Old Mar 26, 2006 | 09:03 AM
fordinmudd's Avatar
fordinmudd
its the bracket you need to make the dana 60 axle fit on a 250.i thought it was called a dop down bracket.it has 6 holes in it one end conects to the truck the other end to the axle.
Old Mar 26, 2006 | 09:22 AM
fordinmudd's Avatar
fordinmudd
it connects where the old dana 50 use to pivot on the truck in the center.anyone that has done the dana 60 swap on their 250 has to have one.
Old Mar 26, 2006 | 10:18 AM
monsterbaby's Avatar
monsterbaby
Say what? who says anyone that does that swap has to have a bracket running from the pivot point to the axle? You've got me totally lost most people are cutting that bracket off cause it's in the way or adding enough lift to clear it.
Old Mar 26, 2006 | 11:25 AM
bremen242's Avatar
bremen242
I think he means the trackbar bracket for the dana 60???
Old Mar 26, 2006 | 11:35 AM
monsterbaby
I was thinking that too but the track bar usually mounts to the frame not in the middle of the truck.
Old Mar 26, 2006 | 12:06 PM
proeliator's Avatar
proeliator
He's GOT to be talking about the trackbar. I guess But even then, you don't HAVE to have one...
Old Mar 26, 2006 | 12:08 PM
chrono4's Avatar
chrono4
i was thinking trackbar too, but using the middle pivot point would give really bad angles and serious bumpsteer. are you going to leafs? or did you get it changed over to coils?
Old Mar 26, 2006 | 10:45 PM
bremen242's Avatar
bremen242
I agree, but I believe the 80s-90s trucks mount off of one of the pivot bracket mounts.
Old Mar 26, 2006 | 10:50 PM
fishmanndotcom
thats a track bar, and you dont NEED one but it might be a good idea esp if you have play in the front end (like old bushings or worn out springs)
the trac bar bolts right in place of where your TTB brackets were on the engine crossmember.
-cutts-
Old Mar 26, 2006 | 10:52 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
you dont need the tracbar if you have a good H style shackle, but with the stock A frame shackles the front will have some slop to it
Old Mar 29, 2006 | 07:09 PM
fordinmudd's Avatar
fordinmudd
im not talking about the track bar!!!!!! im talking about the drop down bracket ill take a pic and post what im talking about later.
Old Mar 29, 2006 | 07:16 PM
monsterbaby
yeah that would help because a D60 solid axle should only be attached to the frame by the springs and the trac bar if used.
Old Mar 29, 2006 | 07:18 PM
FordPickMeUp's Avatar
FordPickMeUp
i think i know what bracket your talking about.I have a pic of it from my truck here it is.its the goldish bracket in the center of my pic.
