fuse box
Old Mar 25, 2006 | 10:45 PM
wtlcruiser's Avatar
wtlcruiser
fuse box
I have a 63 unibody...where is the fuse box located? The horn is no longer working...Also, can't get the wiper to work either...
Thanks in advance,
Luis
Old Mar 26, 2006 | 09:15 AM
drof46's Avatar
drof46
I have a 64 so I'm not for sure if it will be the same, but try looking under the light switch for the fuse box. The horn could be several different things. With your numerous problems I would suggest pulling the dash and looking for loose wires bad connections(use a tester with the little red light to see if your getting power to the horn and to the wiper motor). Horn could be a bad relay, brush not making contact, bad horn etc... You can undo the horn button and use your tester to see if your getting current to the contact brush. If you are it could just be a bad relay(don't know where yours would be, mine is in the engine compartment attached to the fender well near the voltage regulator). Good luck, maybe a unibody guy will post on hear if I'm way off track.
ihfarmboy93
Feb 22, 2015 11:08 PM
NickOlsen53
Apr 13, 2014 02:11 PM
JOEPICKUP
May 14, 2012 09:37 PM
hockey101
Electrical Systems/Wiring
Jan 25, 2004 06:28 PM
manvan
Jun 22, 2003 07:59 PM
