Getting ready to epoxy my kids bronco- doing the lower end with a roll on- need a decent, consistent texture. I need to apply liner over epoxy and am not getting any answers from companies whether thats ok...what do you think? Will go with a simple poly if that will work.
I want to primer in the next couple of days and got some omni au mp170
spent a couple more hours and it looks like poly should go over epoxy- no one addresses it outright but will give it a go...posting pics soon as this is quite the project- butt welding 3 pieces in and am really struggling with the rear gate on this bronco- major rust and previous owner was very skilled at using bondo but covered up a bunch of oxidation- some areas have a good 3/8" of bondo over rusting metal. giving por 15 a real test.
got the gallery with pics up if you want to gander at them.
I'm not putting epoxy on with a roller like my first post suggested . I'd still like to hear if anyone has applied a poly roll-on liner over fresh epoxy primer. I've searched a ton w/o anyone addressing it directly. Spraying epoxy on wed early pm.
thanks
