85 F-250 - Starter Problems
Old Mar 27, 2006 | 07:14 AM
dell's Avatar
dell
Originally Posted by Bdox
If you short between the large terminal with the battery + cable attached, across to the small terminal marked 'S' it should crank. Try that first and get back with the result.
Tried it and still nothing. I'm thinking I may have to get those wires grounded?
Old Mar 27, 2006 | 09:39 AM
Bdox's Avatar
Bdox
OK, check all the heavy cable connections.
1, battery + to solenoid. 2. solenoid to starter terminal. 3. battery - to ground. 4. engine to chassis.
That is eight cable ends. Clean them all and the surfaces that they contact. Apply a little grease to them all to prevent corrosion. Good tight clean connections might take care of the problem, but it should be done anyway just as a matter of maintenence.
Keep us posted.
Old Mar 27, 2006 | 11:42 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
I had a bad Negative battery cable that went to the starter casing. Replaced that and it started great.
The cable went from the negative post on the battery, to a grounding spot on the frame, then it went to one of the bolts on the starter that holds it in place.
eckart
Jul 24, 2013 06:35 PM
officer131
Sep 30, 2012 12:09 PM
bohiaa
Mar 5, 2009 05:17 PM
Clouth
1997 - 2003 F150
Oct 24, 2005 08:54 AM
ford4life69
20
Jan 1, 2003 06:48 PM
