Which Carb is it?
Old Mar 25, 2006 | 08:12 PM
RickardC's Avatar
RickardC
Which Carb is it?
I have a 1981 F-250 Ranger, extended cab, full length bed, 351. The carb on the engine is a Motorcraft Variable Venturi. It needs to be replaced with a rebuilt, but I've read on this website that VV's are not to be trusted. Can I replace it with a different carb? If not, what is the carb model I should order from a rebuilder?
Old Mar 25, 2006 | 09:34 PM
Ford_Six's Avatar
Ford_Six
If the truck has Duraspark II ignition (vacuum advance on distributor), then you should be able to just throw a regular Autolite/Motorcraft on it. If it has the TFI ignition, then you may have to chang the ignition system out as well.
Old Mar 25, 2006 | 11:07 PM
LxMan1's Avatar
LxMan1
Holley used to make a direct replacement that had all of the hook-ups like the VV carb, including the TPS sensor and air valve in the rear, but it was a regular carb. I put one on an 80 351W in a Crown Vic my dad used to have and it ran 100% better. It may still be available.
