What does this sound like?
Old Mar 25, 2006 | 07:33 PM
AZwhite350's Avatar
AZwhite350
I was coming back from the stables today and noticed some vibration. I figured it was a rock in a tire, so I didn't pay much attention. Then when I got to a redlight, the diesel was vibrating and almost pulsing. The valves were making lots of noise. It was down on power some - not a whole lot, but if I stepped on the accelerator it started vibrating pretty badly.
It ran fine on the way over to the stables (40 miles). I did have to fill it up today and added 8 ounces of a 50:50 mix of Marvel mystery oil and Dieselkleen, but I did that before I headed over to the stables.
BTW it is an 06 PSD CC F350 auto with about 4000 miles.
Anyone have any ideas. I did check the turbo hoses and they are all connected.
If it is nothing obvious, I'm taking it to the mechanic on Monday.
Old Mar 25, 2006 | 08:03 PM
tvsjr's Avatar
tvsjr
I don't think I'd tell Ford about using Marvel Mystery Oil in the fuel tank... sounds like a great way to get your warranty voided.
Old Mar 25, 2006 | 08:39 PM
Maxium4x4's Avatar
Maxium4x4
Sounds like a good idea to me. Let us know what they find.
Old Mar 25, 2006 | 08:40 PM
PupnDuck's Avatar
PupnDuck
Not only what tvsjr said, but if memory serves, Marvel Mystery Oil is RED. Wouldn't want the dealer making any false assumptions about what type of diesel fuel you've been burning (untaxed, off road fuel is red).
Old Mar 26, 2006 | 12:01 PM
AZwhite350's Avatar
AZwhite350
I only added 8 ounces of a 50:50 mix and then put over 20 gallons of diesel on top of it.
Sounds like it is going to the mechanic tomorrow.
Old Mar 28, 2006 | 06:36 AM
AZwhite350's Avatar
AZwhite350
Bad injector - they replaced one and kept the truck overnight to check the others when it starts up cold this morning. Will know more later today.
Old Mar 28, 2006 | 05:51 PM
Maxium4x4's Avatar
Maxium4x4
Kind of weird injectors problems are cropping up again. See how things go now on start-ups.
Old Mar 28, 2006 | 10:19 PM
AZwhite350's Avatar
AZwhite350
It was indeed the injector on #5. All is well now - however it does take a little more cranking to start now for some reason.
Old Mar 28, 2006 | 10:36 PM
vloney's Avatar
vloney
theyre supposed to drive the vehicle for 20-25 miles after injector replacement to purge the high pressure oil system of air bubbles. If they dont, hard starting occurs.
Old Mar 28, 2006 | 11:12 PM
big inch's Avatar
big inch
That's true about purging the air. The problem is that Ford won't pay to do it.
Old Mar 29, 2006 | 07:24 AM
vloney's Avatar
vloney
yeah, been there-done that. I usually get one of the kids in the detail shop to drive them--they like the opportunity to goof off legitimately
Old Mar 29, 2006 | 12:59 PM
AZwhite350's Avatar
AZwhite350
I notice that it starts easier each time I start it up. First time after the injector install, I cranked it 3 times of about 5 seconds each before it would start.
