1966 - 1977 Early Broncos
question on vin # location?
Old Mar 25, 2006 | 07:07 PM
Fine250's Avatar
Fine250
I'm looking at a '68 Bronco and wondering if anyone can tell me where the vin # is located so I can match it with the title.
Old Mar 25, 2006 | 09:20 PM
eveready77's Avatar
eveready77
should be inside the drivers door jamb, above the striker bolt, just below the top of the bed rail.
Old Mar 26, 2006 | 05:59 AM
Fine250's Avatar
Fine250
Thank you for your answer.I thought I looked there but maybe not well enough.Is it also stamped into the frame possibly?
Old Mar 26, 2006 | 09:09 AM
eveready77's Avatar
eveready77
It is on the trucks but I'm too shure on the EB's. I'm just starting to mess around with them.
Old Mar 26, 2006 | 10:49 AM
BigFord74's Avatar
BigFord74
Would that be true for a '77 wife has to file for a lost title on hers. O btw anyone know what size of rim i can put on a stock '77 uncut? Wife went back home to get the vin numbers so we could move her to where we live now and i guess someone decided they needed the wheels and tires more then us. Guess on the bright side they left it on blocks. I'm just needing a size so i can get some junk rims to get her moved.
Old Mar 26, 2006 | 11:09 AM
Fine250's Avatar
Fine250
Found out from another web site that the vin # is located on a tag that is on the inside of the glove box door on a '68 bronco.
Old Mar 26, 2006 | 12:46 PM
eveready77's Avatar
eveready77
Fine 250, glad you found it! If you have more questions feel free to shoot them this way!
BigFord74, Yes it should hold true for the 77's too. My 74 has it in both places. As to the wheels, I believe they are 15x7 from the factory. My 74 is un-cut also and I would be afraid to go any wider than 8", even that is pushing it with out a lift. Bolt pattern is 5 on 5.5". most all half ton fullsize ford trucks and vans used this bolt pattern, along with fullsize dodge rams and earlier cj jeeps. If you go junkyarding take a tapemeasure with you and verify the spaceing before you take them home. Some f-100's and I think f-150's in the early '80s used a smaller bolt pattern like the one used on rangers and full size cars like the crown vic...these wont work. Hate to hear about the theiveing, hope y'all get it straightend out! -eveready77
Old Mar 26, 2006 | 05:20 PM
McLeod's Avatar
McLeod
On my '67 the vin was stamped into the top of the frame rail on the passenger side just below the firewall. You can faintly see it from outside the passenger front wheel opening, just behind the rear of the starter.
Try to get a mirror up there. It would be a bugger to see if it was dirty, so clean it well! Maybe rub some chalk into the numbering to make more visible.
I think this was a "hidden" location to aid law enforcement in detecting stolen vehicles.
The vin should also be on a tag on glove box door, but with how easily these parts interchange I'd question the authenticity of it.
Regards
Ken
