Mechanical Fuel Pump Eccentric
Old Mar 25, 2006 | 03:27 PM
hunter1897's Avatar
hunter1897
Unhappy Mechanical Fuel Pump Eccentric
I am rebuilding a 1989 5.0 roller block engine that was from an EFI Stang and am carburating it for my Bronco. I know I need to use a fuel pump eccentric, and an engine buddy of mine gave me both a 1-piece and a 2-piece to choose from. My question is, which should I use and why? I would presume at the very least they are probably both interchangeable (I'm going to check all their dimensions tonight with a digital caliper), and if so, I would think the 2 piece might be a bit better for less friction, but maybe I'm wrong. Is one for a 302 and one for a 351??? Thanks in advance.
Old Mar 25, 2006 | 03:50 PM
baddad457's Avatar
baddad457
Use the 2 piece eccentric. The cam drive pin is likely too short to engage the thicker 1 pc. Some timing covers also interfere with the 1 pc. Ford used the 1 pc till sometime around the early 70's then switched to the 1 pc for all V8's.
