Trans swap
Old Mar 25, 2006 | 02:46 PM
Young_unn's Avatar
Young_unn
Trans swap
will a c-4 be able to be switched in place of my original 3 spd and 223. my trans has a floor shift that gone back,( needs shifter rods and whatnot) also the clutch is gone.
what will be need to make the switch. will they match up?
Old Mar 25, 2006 | 09:08 PM
FordBoypete's Avatar
FordBoypete
Thumbs down
Short answer is NO, they will not match up &/or bolt up for a lot of reasons. . . .
Sorry!
FBp
Old Mar 25, 2006 | 09:52 PM
FirstTry's Avatar
FirstTry
close to topic-
what about a C6 onto a 352 that had a 3 on the tree
Old Mar 25, 2006 | 10:25 PM
FordBoypete
Yeah, Sure,
If it's going in a 65 or later Slick & C-6 is for an FE engine, not something else.
Also if you get it from an F Series you won't have to Flip shifter lever & you can use a TVR / Throttle Valve Rod [aka kickdown rod] from F series thru 76. it will all fit and work for you.
If you get an FE style C-6 from a "P"-car you'll have to massage a few things to make it work as a "plug & play" installation. It all will fit but it won't work for ya without flipping a lever, getting right TVR, some car models may give you a time w/rear trans mount too.
FBp
Old Mar 26, 2006 | 04:48 AM
jowilker's Avatar
jowilker
Hey Pete, Can you take a moment and enlighten me on the lever flip? I had not known about this.
What and where do we flip? I have a car tranny in my truck and need to either flip or replace the arm one day.
thanks bro
John
oldgrezmonke
22
Oct 15, 2013 03:22 AM
just-n-time
13
Dec 2, 2009 06:34 PM
skipr
Nov 15, 2009 10:02 AM
96DRW
Jun 5, 2007 11:59 AM
bazookabrown
Apr 2, 2005 07:06 PM
