1978 - 1996 Big Bronco
Engine ticking noise
Old Mar 25, 2006 | 10:42 AM
autx790's Avatar
autx790
Sorry to post a random noise question, but here goes.
I have this sound coming from my engine (i believe). It basically sounds like the noise you get when you put a baseball card in the spokes of a bicycle. It gets louder when going up hill or as RPMs increase, but seems to always stay at the same frequency. A friend of mine told me it could be with my valves, something about the pistons slapping around inside or something like that. If anyone has some suggestions about this i'd appreciate it. Also if you think it would be a somewhat easy fix or if I need to try and find a mechanic.
Thanks!
Old Mar 25, 2006 | 11:08 AM
topfisherman's Avatar
topfisherman
It is hard to tell without hearing the sound, but I'd check for an exhaust leak, like a cracked exhaust manifold.
Old Mar 25, 2006 | 12:36 PM
dwoodler's Avatar
dwoodler
Or a bad gasket... Look for soot and carbon blowout onto the head and block. I had to retourque the manifold bolts on the 89 a while ago because I had an exhaust leak. It was the front passenger side bolt that had loosened right off.
Old Mar 25, 2006 | 03:46 PM
yamaweezle's Avatar
yamaweezle
still dwelling on the exhaust noise...my '95 only had one exhast manifold, to cylinder head bolt that was slightly loose...the very rear one, on the drivers side...torqued it up, and the noise was gone...i checked the rest of them, of course...
Old Mar 25, 2006 | 03:53 PM
greystreak92's Avatar
greystreak92
302's are notorious for cracking the passenger side OEM manifold between cylinders 2 & 3 as well. (I used it as an excuse to buy equal-length shorty headers).
Something else to check AND SOON. is the Thermactor check valve BEHIND the intake manifold. They have been known to snap in half when they fail which, in and of itself itsn't a terrible thing, EXCEPT that when this happens you lose Thermactor air to the cylinder heads AND since the Thermactor air is supplied into the exhaust ports, the break in the Thermactor plumbing at that point allows hot exhaust to backflow up through the broken check valve which is immediately below the main wiring harness for the engine that runs along the top of the firewall at the cowl. Gettin' the picture...hot exhaust...wiring harness, check into it just in case. The noise you are hearing may actually be the sound of the air from the smog pump escaping out the end of the broken check valve OR the exhaust backing up through the Thermactor plumbing.
Old Mar 25, 2006 | 07:53 PM
ctch88's Avatar
ctch88
or the pcv valve
Old Mar 25, 2006 | 10:27 PM
geoaigel's Avatar
geoaigel
The fact that it gets LOUDER under load is a giveaway for an exhaust leak. I'd bet money on it. As others have said, it could be anything froma cracked manifold to a bad gasket ...
Check it soon, as mating surfaces can wear from being blasted with hot exhaust.
George
Old Mar 29, 2006 | 09:03 AM
autx790's Avatar
autx790
Well I was getting one of my tips replaced cause its rotted through, and I had the muffler place see if they could find a leak somewhere. Sure enough the metal pipe, which i believe he said connected to the EGR valve, was cracked almost all the way around. Hopefully thats all that was leaking. Thanks for the help!
By the way, speaking of PCV valve, can anyone tell me where that dang thing is?
Old Mar 29, 2006 | 10:56 AM
greystreak92
Its in the passenger side valve cover UNDER the upper intake plenum. the vacuum line from it runs up the back of and into the upper plenum. It can't be readily seen. You have to go looking for the silly thing.
Old Mar 29, 2006 | 01:32 PM
dwoodler's Avatar
dwoodler
I looked for it for a couple days when I wanted to replace mine. It's hid in there pretty well.
Old Mar 29, 2006 | 03:41 PM
geoaigel's Avatar
geoaigel
Yup. Pass side valve cover far back. I changed mine a month or so ago and had to look for it ...
Good Luck, George
Old Mar 31, 2006 | 05:23 PM
jcp123's Avatar
jcp123
I've got that same tick on my 302, started about 6000 miles ago. Always wondered what that was.
Old Mar 31, 2006 | 05:38 PM
autx790's Avatar
autx790
I had that pipe replace and it appears to be all better. Thanks for the advice guys.
baylormcdaniel
2004 - 2008 F150
Jan 10, 2017 08:21 PM
Roadtriptruck
Jun 14, 2016 12:34 PM
Deanp88
6.4L Power Stroke Diesel
Feb 27, 2016 05:13 PM
nexus1467
Feb 17, 2016 05:58 PM
mechelement
May 6, 2015 12:20 AM
