tranny swap
Old Dec 25, 2002 | 04:56 PM
ford_nut's Avatar
ford_nut
tranny swap
guys
I need a little help here. I have a 69 camper special F250 2wd with a 360/C6 combo. The tranny just blew out in it and I want to replace it with a 435 4 speed. How involved is the swap? Do I need any special crossmembers? IS there welding involved? Do I need a special 435? I have a divorced unit out of a 4x4 truck and a married unit out of a 300 six/435 setup. Ive never done a swap like this so I need some help before i undertake such a feat! THANKS AGAIN!
regards
~~NUT~~
Old Dec 25, 2002 | 06:21 PM
stargazer's Avatar
stargazer
tranny swap
NUT,
here is a list...
you will need...
all the clutch pedal stuff
the clutch pivot brackets and linkage
a flywheel and clutch housing for a 360 or 390 if you don't have one
the crossmember is the same reuse it in the foward set of holes
you may also need to change your floor tunnel cover
and the driveshaft all depends on what the truck had with the C6
umm I think thats about it, am I forgetting something?
you might want to change out your auto column to get rid of the extra shifter but you don't have to.
its really a pretty easy swap
Old Dec 25, 2002 | 07:26 PM
1968F250LWB's Avatar
1968F250LWB
tranny swap
F-Nut
Found this and thought you might be interested.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33700&item=1875321 762
Russell
1968 F250 LWB 300-6
FORD=First on Race Day
#88 Dale Jarrett-9th in 2002
#21 Elliott Sadler
#97 Kurt Busch-3rd in 2002
#28 Ricky Rudd-10th in 2002
Old Dec 25, 2002 | 09:11 PM
ford_nut's Avatar
ford_nut
tranny swap
Russ
thanks a lot--that might be something that i might need! you da man! thanks again!
Old Dec 25, 2002 | 09:16 PM
1968F250LWB
tranny swap
No problem man. Please see want Ad Number: 6541 in this sites classifieds and let me know if you can help.
Russell
1968 F250 LWB 300-6
#21 Elliott Sadler
Old Dec 26, 2002 | 06:53 AM
jowilker's Avatar
jowilker
tranny swap
Russel, Is there something wrong with the column or are you just wanting to swap?
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member 0004 since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Dec 26, 2002 | 07:17 AM
1968F250LWB
tranny swap
John,
There is nothing wrong with it except for the fact that in 78 the neutral start switch was mounted on the tranny but in 68 it was mounted on the column. So on the 78 column there is nowhere to mount the switch. Aren't you in NC
Russell
1968 F250 LWB 300-6
#21 Elliott Sadler
Old Dec 26, 2002 | 09:51 AM
ford_nut's Avatar
ford_nut
tranny swap
Russ
i have 2 steering columns complete--they are rough--prob need to be worked on some--came out of a 68 4x4 pickup with manual trans and the other i believe (not sure) came out of a 74?? 4x4 with manual trans..i have em both sitting in my junk pile out here. I cut em out of two of my trucks and the harness is cut. However, I dont think that these columns are what you are after! wish I could help more!
regards
~~NUT~~
Old Dec 26, 2002 | 08:26 PM
Art's Avatar
Art
tranny swap
Be advised that a divorced 435 out of a 4x4 may not have a speedometer provision in the tailhousing - the speedo cable comes out of the transfer case!
Art
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=3467&.jpg
Old Dec 26, 2002 | 11:29 PM
pward76's Avatar
pward76
tranny swap
