Fuel Tank Sending Unit
Old Dec 7, 2002 | 10:29 AM
svt522's Avatar
svt522
[updated:LAST EDITED ON 07-Dec-02 AT 11:29 AM (EST)]Any one know a good source for the fuel level sending unit in the tank of a '67 F100? I've struck out with all the local parts houses!
Thanks for any responses.
Old Dec 7, 2002 | 10:35 AM
flyboy2610's Avatar
flyboy2610
Have you tried the online store at this site?
Old Dec 7, 2002 | 10:51 AM
sullyda1's Avatar
sullyda1
Try www.autokrafters.com. They have "in cab" gas tank sending units for $75.95. Part# DTZ-9275-G. www.ObsoleteFordParts.com lists the exact same unit for $49.95
Old Dec 7, 2002 | 11:22 AM
Mike W's Avatar
Mike W
You might check the cost of an after market fuel gauge and sender combination. Also maybe a wrecking yard.
Old Dec 7, 2002 | 11:59 AM
Mil1ion's Avatar
Mil1ion
Flyboy's Right.
http://motorhaven.autoanything.com/cgi-bin/Web_store/webshop.cgi?yearmodel=&product=GASTANK&cart_id=745 6321_29341&source=
Dennis
F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/SigSanta.JPG
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Dec 8, 2002 | 09:00 PM
sullyda1's Avatar
sullyda1
Interesting range of prices for what appears to be the same item.
Old Dec 9, 2002 | 09:17 AM
badboyina67's Avatar
badboyina67
I bet I can save you all the money of buying one. Most of the time all that is wrong with these sending units are the wipes inside the housing.
Here's how ya fix it.
1. Remove the sending unit.
2. Take the float off the bottom of the sending unit and set it aside.
3. CAREFULLY pry the little tabs that hold the one side of the sending unit together up.
4. Remove the wipe.
5. If the wipe has fallen off, then all you might have to do is put it back on. IF NOT, go to the next step.
6. CAREFULLY solder the wipe back together. Once you get it apart, you will see what I am talking about.
-----Most of the wipes are split into 2 pieces from years of rubbing against the coil inside the sending unit. A little solder and you can easily put it back together.
7. Reassemble the sending unit. When you reattach the float, you should move it up and down. If you feel an ever so slight drag of the wipe riding up and down the coil inside, then you're good to go. If not, try a little more soldering.
I did do this to my truck and still working GREAT. Saved me about $100, too. THe wife LOVES things like that around Christmas:-X12
Hope it helps,
Ken
Old Dec 9, 2002 | 10:26 AM
1968F250LWB's Avatar
1968F250LWB
Here is one on ebay http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1874363288. Currently $9.95!!!
Russell
1968 F250 LWB 300-6
FORD=First on Race Day
#88 Dale Jarrett-9th in 2002
#21 Elliott Sadler
#97 Kurt Busch-3rd in 2002
#28 Ricky Rudd-10th in 2002
Old Dec 27, 2002 | 08:24 AM
svt522's Avatar
svt522
I went to several local junkyards. One wanted $50 and the other $35 for 35 year old sending units! I ordered one from JC Whitney for $25 delivered to my door. I'll let you know how it works when it gets here.
svt522
1967 F100
1985 5.0 Hydraulic Roller Cam Engine
F150 5-speed
9-inch w/4.11 Detroit Locker
Old Dec 28, 2002 | 05:06 PM
OneFine69's Avatar
OneFine69
I installed that aftermarket one from JCWhitney about a month ago and I havent had a problem since. It comes with everything you could need. I would go for that one- if you dont mind having an extra gauge to stash somewhere.
Tristin
Old Dec 28, 2002 | 09:50 PM
Mil1ion's Avatar
Mil1ion
Old Apr 24, 2004 | 06:56 AM
eriksf250's Avatar
eriksf250
fuel tank sending unit
The fuel sending unit for my truck works on and off somewhat. I just recently bought the fuel tank at a salvage yard with the sending unit inside. i shook the tank and turned it to the side where the filler is and rust came out. Later I found out that it's only surface rust. I pull the sending unit to check to see how good it is and it had rust on it. I'm thinking that might be the reason why the sending unit isn't working. Has anyone tried soaking their sending unit in a rust eater like CLR? I wanted to try to get it clean and working. When I put gas in the tank and drove it around, it started working. Could it be that the gas is cleaning the sending unit? Any help is appreciated.
Old May 1, 2006 | 12:02 PM
Franken-ford's Avatar
Franken-ford
could be an intermittent ground^^
hey I went through the question of replacing a sender as well, and i have received the JC whitney universal replacement sender (for ford and chrysler) also like some of those who posted above.
if any of you remember, how far down the float rod did you make the 90 degree bend in it? ("Dimension B" from the instructions lol, only people who have done this operation will know what the heck i'm talking about). here;s hoping. thanks in advance :tup:
working on the gas tank gives me the ******* a little bit so i have been putting it off.
Old May 2, 2006 | 12:45 PM
Franken-ford
^^ well, regarding the datcon/jc whitney, the dimension i went with was 7-5/16.
*** regarding this product in case anyone is considering ordering it-- it does work as advertised, but the bolt hole pattern on the flange part of the sender does not match the tapped holes in the top of the fuel tank: on the OEM sender, the holes are arranged in an evenly spread out pattern, in a true circle with one bolt hole every 72 degrees. However, the holes on the jc whitney replacement are NOT evenly spaced.
the two patterns are so close that all the bolts with start into their holes...
what needs to be done is to carefully remove the ORIGINAL gasket from between the old sender and the tank (or alternatively, to buy a new one, if your gasket can't be removed in one piece. Mine came off fine...) Lay the gasket over the flange of the new sending unit to see where material will need to be removed. it's a matter of 'egging'/wallowing out the existing holes in the new sender enough that the screws can go through in the right location.
i am using the tip of an ogive shaped aluminum carbide dremel bit to egg out the holes. I did this inside the house of course, far remote from the gas tank and its fumes because dremelling out the holes with this kind of bit does make some big sparks, lol.
i had to find some slightly oversized rubber washers for a couple of the egged out holes in the flange, but now the dang thing fits properly, i know how much gas i have, there are zero gas fumes in the cab & i am riding on a brand new sender not a junk yard one, for about 25 bucks.
all in all if i could have found a new old stock sender, fine, it would have been a simpler install & it would be the 'correct' way to go. But my truck is made out of at least 3 different year parts that I am aware of lol, and is kind of a beater really.
i am not trying to hijack the thread or anything, it just seems like people are going to search through these threads for this kind of info at some point & maybe it would help
sorry/hoping it helps someone! frnkn-frd
Old May 2, 2006 | 03:51 PM
BobbyFord's Avatar
BobbyFord
I got mine recently from the Ford dealer.
