Date clarification
Old Dec 28, 2002 | 03:14 PM
oldiron's Avatar
oldiron
Date clarification
Under the oil filter adapter is the cast numbering of 2L12.
Is that december 12th 1972?
Just need a second opinion.
Greg
Old Dec 28, 2002 | 05:09 PM
Mil1ion's Avatar
Mil1ion
Date clarification
L is November.
Ford NEVER used the I in their coding.
2L12 November 12 > 1952,1962,1972,1982,1992,2002 <
Depends on the other Casting number for part ID.
Dennis
F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/SigSanta.JPG
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Dec 28, 2002 | 08:17 PM
oldiron's Avatar
oldiron
Date clarification
Didn't know that about the I, good info to know.
As for the rest it's a 4.05 bore with a 2U crank, so I'm reasonably certain it is as advertised...390. All the other signs are there as well. Thanks for the insight.
Greg
Old Dec 29, 2002 | 11:43 AM
flyboy2610's Avatar
flyboy2610
Date clarification
You can make certain it is a 390 by measuring the stroke.
Pull one of the spark plugs, then use a socket on the crankshaft pulley bolt, turning it CLOCKWISE ONLY. Put a stout piece of wire or a small diameter wooden dowel in the hole, them put that cylinder on BDC. Mark the wire or stick, then run it up to TDC. Mark the stick, then measure between the two marks. If it's 3.78" you have a 390. If it's 3.5 you have a 360.
Old Dec 29, 2002 | 01:46 PM
1970f2504x4's Avatar
1970f2504x4
Date clarification
