PCM Removal
Old Mar 23, 2006 | 09:03 PM
nubby3's Avatar
nubby3
PCM Removal
How do I remove the PCM?I want to remove the PCM so I can get the I.D.off to order a DP chip.Also how to clean the board where the chip needs to be installed.
Old Mar 23, 2006 | 09:46 PM
jtharvey's Avatar
jtharvey
Got to the engine compartment. The computer has a plug there with one 10mm bolt in the middle of it. Loosen that bolt, it won't come all the way out so don't worry about losing it. Once the bolt is loose, you can pull the connector off. It's big, probably 2" wide by 6" tall. Once that's loose, go inside the cab to the driver's footwell. The computer is held in with 2, 7mm bolts, gold in color I believe that are toward the rear of the computer. They just go through the plastic housing tabs. Once they are loose, it may take a little working and wiggling, but the computer will come out with the black plastic case. You'll find the numbers on the end that connects to the harness. Jody will send you some instructions on cleaning the board, but you basically use a scotch brite pad and some acetone until all of the silicon is gone.
Old Mar 23, 2006 | 11:11 PM
Kwikkordead's Avatar
Kwikkordead
I don't think you need to remove it to see the ID of the computer. What you need to do is to remove the two screws on the cover that protects the ECU. The cover for the contacts is just under the cover and you need to push it to the right to gain access. You'll see a code on the cover and a bar code as well. For instance mine is VXY2, a certain program that is F-550 specific. Your's will be different, they have a couple hundred different variations.
Old Mar 23, 2006 | 11:38 PM
jtharvey's Avatar
jtharvey
I didn't even think about that one. Just went and looked at that cover (since it's in a drawer in the workbench) and sure enough, there it was, NVK5. Kwik, it sounds like your cover was a little different than mine though. My case surrounded the ECU on both sides, so it couldn't have been pushed to just one side. But, it probably still could have been slid back a little rather than take it out to see the number on cover where the chip goes in. Oh well. I didn't find it that difficult to remove the ECU.
Old Mar 23, 2006 | 11:54 PM
Kwikkordead
And I am going on year old memories for this one, so take it with a grain of salt. Please.
Old Mar 24, 2006 | 08:18 AM
cangim's Avatar
cangim
On my buddies 2000, I told him to remove the two screws, angle the PCM, and he was able to read the codes. So it can be done that way, but may also depend on where they place the sticker on that particular PCM as well.
Old Mar 24, 2006 | 08:28 AM
codyjoe's Avatar
codyjoe
you can also use a flash lite and a mechanices mirror and look on the side of the connector...i cant remember which side though, think it was twards fender....
Old Mar 24, 2006 | 11:17 AM
jtharvey's Avatar
jtharvey
Will do kwik, will do. Of course, it's very possible that the housings for the PCM could be different. The other option I remembered is to no unbolt anything. If you have a mechanics mirror, you might be able to see the code on the side of the ECU connection that's in the engine compartment. It will be facing the diver's side of the truck. You'll be looking for the biggest set of letters and a number, like PMT1, PMT2, NVK5, etc...
Old Mar 24, 2006 | 03:59 PM
72Lester's Avatar
72Lester
Yep..toward the fender. Good flashlight and small mirror. Label runs down the entire side of the connector.
Old Mar 24, 2006 | 08:08 PM
nubby3's Avatar
nubby3
Thanks everyone for the help.Time to order my chip.
Old Mar 25, 2006 | 12:04 PM
Muktown's Avatar
Muktown
when you pull out the pcm to clean the contacts for the chip remember to take the keys out of the ignition. you might want to disconnect the battery just to be safe. i havent unhoked the battry and it seems to work fine, but others say to disconnect it
Old Mar 25, 2006 | 12:09 PM
John7894's Avatar
John7894
Where eexactly in the PCM does the chip go?????? Supposedly I already have a chip. I need to remove it so i can flash the PCM with my Predator.
Old Mar 25, 2006 | 02:16 PM
Kwikkordead
A chip and a tuner will never work together. The chip will overwrite the Predator tune.
You plug the Predator into the data port that is sticking out of the bottom of the dashboard just in front of your right leg as you are sitting in the driver's seat. You do not need to remove the ECU for that.
Old Mar 25, 2006 | 03:45 PM
John7894's Avatar
John7894
I know Kwik, but I need to remove the chip that's supposedly in there. It's got to have one in there. The PCM is sitting loose in the bracket. It won't slide far enough forward to allow the plastic cover to bolt down to the bracket.
Old Mar 25, 2006 | 03:51 PM
cangim's Avatar
cangim
Obviously this is with the previous Superchip I had, but it gives you the idea of where the chip goes on the PCM, the pic was taken 90 deg off, so tilt you head to the left
