ABS flashing
Old Mar 23, 2006 | 05:51 PM
edwardo's Avatar
edwardo
ABS flashing
The abs light on my '94 f-350 started flashing 7 times after awhile it changed to 16 flashes.please help,I did a search but i'm still not sure where to start looking.
Old Mar 23, 2006 | 06:39 PM
edwardo's Avatar
edwardo
never mind i just found the problem.my brake lights were not working,problem was rear taillight wire was touching ground
Old Mar 23, 2006 | 08:29 PM
Torinofatblock's Avatar
Torinofatblock
I have the saem problem, where was your ground? I'm stuck!
Old Mar 23, 2006 | 08:43 PM
edwardo's Avatar
edwardo
Under the box back by the rear bumper wires run from one taillight to the other.
they may also go to trailer wiring then up to the front of the truck.One of the wires going to the trailer plug on my truck had rubbed through the insulation and shorted out on the body.I taped up the wire then replaced the fuse #13 and everything works good again.you should also check the plug on the master cylinder to see if it has come off or if the wire is damaged.
