Considering buying...
Old Mar 23, 2006 | 05:25 PM
rusty70f100's Avatar
rusty70f100
My dad is considering buying a new Ford. F150, 5.4L Flex Fuel engine, probably a crew cab, 4x4, XLT, 3.55 open differential.
He is concerned about gas mileage and reliability above all else. Will the new 2006 F150 provide this? What gas mileage can he expect? How many little issues can he expect? He also appreciates a smooth ride, will the Ford provide this?
He currently has a 2000 Chevy Silverado, with the 4.8L V8. When it was new, it got 20mpg on the highway (all time max was 23mpg on a trip to Mississippi). Then they (GM) did an "emissions recall" and that number dropped to 17mpg highway, max, and also affected drivability when cold. In-town mileage also took a giant nosedive. It has also has a mild piston slap issue when cold since new. I think a recent issue with the turn signal kind of put him over the edge. Ford doesn't pull that kind of thing, re-flashing the computer and ruining mileage, do they?
Will he be disappointed?
Old Mar 23, 2006 | 05:49 PM
superrangerman2002's Avatar
superrangerman2002
I sure love my '04 F150 that I picked up as a Ford Certified used when Ford was running thier Keep it Simple Plan. The 60 month 4.9% with a 75K bumper to bumper was just too good to turn down on a truck that only had 14,000 miles vs going for a new '05 F150.
FWIW, I really like my new F150 SuperCrew depending on speed 20 mpg at 55mph is not out of the realm of possiblilties with a 5.4L and 3.73's. Most see a high of around 18 mpg. There's just too many varibles to say what mpg you'll really see. IMO the EPA estimates are fairly close.
Not really any pressing issues per say, most have been ironed out by now.
As far as ride goes, words can't describe. You'll have to ride in one for your self.
FWIW the new '06 F150 Super crews are available with a 6.5' box, or the standard 5.5' box if he's thinking about the crew cab route. I'd also reccomend the 5.4L and a 3.73 gear ratio....might want to think about the payload pkg. if he's into travel trailers and such.
Old Mar 23, 2006 | 06:52 PM
rusty70f100
Well, the most he's ever going to tow, is a small bass boat. Is there any possibility the 3.55's will provide better mileage than the 3.73's? Or just get the 3.73's and be done with it?
He does plan on getting the trailer tow package so he gets the hitch and wiring harness.
Old Mar 23, 2006 | 07:14 PM
Never Locked Out's Avatar
Never Locked Out
This is a cool accessory to add to any truck. We have a new patented product called the Hitch Safe Key Vault that fits into most 2 inch receiver hitches. This allows you to store a spare key inside the receiver hitch that can only be accessed using your own personal 4 digit code. You will never be locked out of your truck again. We have complete videos on our web site showing how it works and how to set the combination. We currently have a promotion on our site giving one away for free. All you need to do is visit our site and register to be qualified for the give away.
Feel free to share the contest with your friends.
Thank You
Dave Jabas
Old Mar 24, 2006 | 07:59 AM
superrangerman2002
The 3 valve 5.4L does get better mpg with deeper gears. It seems odd but it's pretty much the truth.
My '04 Supercrew 5.4L 4x4 with 3.73's gets better mpg than my previous '02 Supercrew I used to have with a 5.4L 4x4 and 3.55's....Not to mention it can tow alot more too!
If he goes with 3.73's he'll be able to up grade to a bigger boat if he needs too.
Here's a link to the 2006 F150 specs if you haven't already seen them.
Old Mar 24, 2006 | 12:49 PM
rusty70f100
3.73's it is then!
I do like the 9.8:1 compression ratio. Sounds like it should be an efficient motor.
Thanks for your help!
Old Mar 24, 2006 | 01:14 PM
motleycruef150's Avatar
motleycruef150
Show your Dad the truth about trucks:
http://www.fordvehicles.com/trucks/f150/truth
Ford is the truck leader and frankly that is the net result from buidling the best product. Ford has been the sales and market leader since 1977. When you get done here, you're going to know the truth about trucks!
Old Mar 24, 2006 | 01:21 PM
rusty70f100
Yeah, we got the DVD from the dealer. We watched that about a week ago. They go on and on and on about the frame, which is nice, considering it's fully boxed and reinforced and such. I like the giant bolts that hold the bed on too. I did notice though, that they didn't say one word about the engine.
Old Mar 24, 2006 | 01:57 PM
motleycruef150
Watch it again. They say a lot about the handling, best in class low end torque, the performance, and how well it hauls and tows. Isn't it funny when it comes to the truth about trucks, it's as much about wo, as it is about go.
http://www.fordvehicles.com/allnewf150/popup.asp?deepLink=strength&bannerid=FV10005
Old Mar 24, 2006 | 04:00 PM
johntucker09's Avatar
johntucker09
ok, its not a 5.4L (or a Flex Fuel)....
I have a 2005 SuperCrew, Purchased New Last November...It has the 4.6L, I did get the 3.73LS, and the 5.5 foot box...It will hold anything I put in it, as long as I keep the tool box off of it...I can get about 19MPG highway, and it has plenty of power for me...it tows 6800LBS, which some consider a little weak, but thats more than most camper trailers (No, never towed one with it)...I had a 1995 F150 SuperCab and this truck is definitely better....Handling, Suspension, Ride Quality...I've had a couple of rattles (Bad EGR and a Loose Brake Line) but this truck has been awesome in the four months I have owned it...it has 6800 miles on it now...
One thing I do recommend...try to avoid Continental Tires...See if your dealer can change them out for you...thats been my only complant...they spin too easily...
