question for 72 Camper Special
Old Dec 31, 2002 | 05:42 PM
FuelInjected1's Avatar
FuelInjected1
Old Jan 2, 2003 | 05:25 PM
Seifferlein's Avatar
Seifferlein
I read your post about the Volvo mounting plate for the stereo and went out and bought one. Did you put in a CD player or an older style stereo with *****? I understand the part where you said you drilled through the plastic tabs into the ears on the dash, but how did you attach the stereo to the mounting plate? Did you use any other brackets to hold up the stereo or is the mounting plate the only thing that holds it up?
thanks for the great idea
brad
Old Jan 2, 2003 | 05:34 PM
72 Camper Special's Avatar
72 Camper Special
The mounting kit fits in upside down. I put in a DIN stereo. I used a backstrap to a bolt that looks like it just holds a clip for a wire. The nut is on the underside of the cutout for the factory speaker. Just bend the ears back and drill into them with an angle drill sideways to mount the faceplate kit. Shouldn't be too hard unless you already had a radio and had the whole aluminum thing across the front of the ears. bryan
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
