Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
rear end ID
Old Jul 5, 2002 | 05:14 AM
BrettCox's Avatar
BrettCox
rear end ID
Old Jul 6, 2002 | 11:09 AM
Supercab's Avatar
Supercab
rear end ID
When I change 3rd members in my 9" rear I take a cable tie and hook the metal tag(if I've got it) and the speedo. gear to it, right through one of the mounting holes, so it will all be there when I want to use it again.
Old Jul 7, 2002 | 07:33 PM
Torque1st's Avatar
Torque1st
Posting Legend
rear end ID
Good tip! you must be an "organized" person
If you don't have a metal tag... Clean off a nice smooth spot (grind if necessary) right there on the side of the pig where the tag should be. Use a letter/number set to stamp in the ratio and any other info known.
You might also want to tag the speedo gear with the tire size.
