84 f250 timing problem
Old Mar 23, 2006 | 08:34 AM
1984f_250's Avatar
1984f_250
when i went to check my timing on my I6 f250, i couldnt find the black wire that the decal said to disconnect. where is the wire? or what would the wire be connected to.
Old Mar 23, 2006 | 10:09 AM
nsshirai's Avatar
nsshirai
shouldn't it be the only other wire coming out of the distributor that doesn't go to a spark plug or the coil? i think it comes out of the bottom...
Old Mar 23, 2006 | 02:13 PM
1984f_250's Avatar
1984f_250
there are more wires
i thought that would be the case, but i found 2 multiwire connectos and 2 of them are black
Old Mar 24, 2006 | 07:19 AM
Chiefrider007's Avatar
Chiefrider007
No expert but I would think the only thing you would have to disconnect would be the vacuum line from the carb. Plug it, time it, then when you reconnect it should pick the idle up just a little.
Old Mar 25, 2006 | 12:32 PM
Bdox's Avatar
Bdox
Do a search for "Spout Connector"
