Offroad & 4x4
winch for a trailer
Old Mar 23, 2006 | 07:50 AM
fellro86's Avatar
fellro86
winch for a trailer
Ok, I have one of the cheapy winchesfor my trailer, and it does ok for cars, but strains. For trucks, I have to help it with a come along. I also am using a ****** block, without it, the winch couldn't handle it at all. So what I am looking at is what winch will be able to pull the average light truck on without being over worked. I have no issues with continuing to use the ****** block, and unfortunately, budget is slim. Brand isn't important, what is important to me is that it can do the job. I'm not up to these hand pulls anymore... Every so often I have to pull something that doesn't roll so well, wrecks and such, or stuck tires, so I need to know what would work. $3-500 is about what I can spend.
Old Mar 23, 2006 | 08:27 AM
fishmanndotcom's Avatar
fishmanndotcom
ok well tell us exactly what kind of trailer (as in how steep are the ramps and how long is the deck and all that) and what kind of winch do you have now?
i would say a 8,000lb cheapey would do the job, but i am not sure
-cutts-
Old Mar 23, 2006 | 09:58 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
i would rather have a 500 dollar used warn than a 500 dollar brand new peice of crap winch
in other words i think i would find a good used winch
Old Mar 23, 2006 | 11:34 AM
ivanribic's Avatar
ivanribic
What's with this Tabor . . . is it really Warn or are they just playing the name game? Price wasn't too bad: http://cgi.ebay.com/ebaymotors/Warn-...46879007QQrdZ1
Seems even the used Warn winches go for pretty big money. 'Course you could always use the winch you have now and just use a couple ****** blocks. There's no problem you can't fix with enough pulleys.
Old Mar 23, 2006 | 12:08 PM
tjc transport's Avatar
tjc transport
i ain't rite
i have a 9,000lb Ramsey planetary gear drive mounted on the front deck of my trailer. i have yet to find anything it will not drag out of the woods and up onto the trailer.
Old Mar 23, 2006 | 02:14 PM
fordraceboy's Avatar
fordraceboy
and a couple of hundred extra feet a 9/16 line.... not that i'd have any experience with that or anything...
Old Mar 23, 2006 | 04:32 PM
chrono4's Avatar
chrono4
if it was me, and i had some cash, id save up for a whinch for the truck, mount it on a reciever, and then just weld a reiciever to the trailer, just move it as you need it. how are you powering it?
Old Mar 23, 2006 | 08:42 PM
fellro86's Avatar
fellro86
Well, the plan is to be able to move it, as I actually need it for 2 trailers, but both have a fairly gentle angle, 5' long ramps for about a 2' rise. (one is 2 car, one is single) I plan on making the winch moveable, because I don't want to leave it out in the weather to try and make it last longer. My truck doesn't have a receiver, it is an ag hitch, with the moveable tongue. I will likely have to use a battery close to the winch, and then run a charge wire to it.
One problem I have with my current winch is that the power leads are shorted out in the plug, I would have to totally bypass the plug to make it work again... it was a wimpy thing, couldn't pull a 3500# car on straight line, even though it was rated at 4000#, threw the over heat breaker on it. It was a Harbor Freight special... It has done ok, but I need to get a little better.
Old Mar 23, 2006 | 09:33 PM
Big_Al59's Avatar
Big_Al59
I got a 9000lb Tabor winch for a christmas present last year. I had some of the covers off during the install, all the parts I could see said warn on them.
It's pulled my 97 psd out of the snow and mud a couple times this year, just
pulled out a dodge 1500 out last weekend. So far so good.
Old Mar 24, 2006 | 12:01 AM
ivanribic's Avatar
ivanribic
Good info. At $500-$600 the 9000lb Tabor didn't look like too bad a deal, I just wasn't sure about the quality.
Old Mar 24, 2006 | 08:45 AM
tjc transport
i ain't rite
for battery power and charging, i mounted a battery on the deck next to the winch, and use a solar panel to keep it topped off.
Old Mar 26, 2006 | 06:39 PM
ncranchero's Avatar
ncranchero
Our tilt deck trailer built in 1984 with a 8000 lb Warn. If you can hook to it, it will drag it!
http://i11.photobucket.com/albums/a1...arTrailer1.jpg
Old Mar 26, 2006 | 07:39 PM
2classics's Avatar
2classics
I knew a guy who had an 8 hp briggs hooked to a studabaker 3sp with a wormgear drive drum on his trailer. Don't know what he NEEDED it for but you could pull a bulldozer on there if you had axles to hold it and about 5hrs to do it in.
Old Mar 26, 2006 | 10:20 PM
KubotaOrange76
now hats an interesting setup, i would like to see that
Old Mar 26, 2006 | 10:23 PM
fishmanndotcom
lol yea i would too!
i have decided i am going to make a receiver mount for my 8274 and build reciver hitches for our trailers. then i can use it on my truck and any of our trailers as well as being out of sight/out of mind and out of the weather!
-cutts-
