got a few different issues. need help from the pros
Old Mar 22, 2006 | 10:09 PM
79shovelhead's Avatar
79shovelhead
First off, my abs light came on the other night. today I changed the sensor in the diff. problem not fixed. master cylinder is full. what else makes these things stay lit. everything feels normal. Also, I did my 4inch exhaust today and straight piped it. 4 INCH FROM TURBO BACK. I did the quik mod 6637 too. I am running jodys chip. It seems like I lost some bottom end grunt.Before this I was running napa gold filter with stock box and stock exhaust with adapters to a 4 inch magnaflow. Is it because i have no backpressurre now? The truck seems to really smoke more now too. It clears when the rps go up but I dont feel the powerband I had before. Turbo looked good too.
Old Mar 23, 2006 | 06:46 AM
tjbeggs's Avatar
tjbeggs
your abs light could be front wheel speed sensor if it 4wabs. could be a computer issue, could be abs valve issue, could be a wiring issue, could be about everything else even you new sensor at the rear (bad out of the box). any time there is a light on the dash it will tell you where to start looking if you have it scanned.
Old Mar 23, 2006 | 11:23 AM
SpringerPop's Avatar
SpringerPop
Shovelhead,
I was having intermittant ABS lights, too. Wasn't VSS. As TJ said, it could be sensor if you have 4-wheel ABS.
Jack up your front end, getting the tire off the ground.
Placing your hands at the top and bottom of the tire, try to "rock" the tire.
Repeat on the other side.
If one's loose, you likely need a replacement hub assembly.
Did one of mine yesterday for this very reason.
Pop
Old Mar 25, 2006 | 11:05 PM
79shovelhead
how much did the hub assembly cost and how long did it take you
Old Mar 25, 2006 | 11:10 PM
SpringerPop
"Friendly" deal was $285, but got it for $249. About three hours, just putzin'.
Wait a minute! Your profile says you've got an '87 250. Is this the truck we're talking about? If so, you don't have the sealed hubs at all.
Pop
Old Mar 25, 2006 | 11:28 PM
79shovelhead
shoot, I havent changed my profiile, I have an 01 superduty 4x4
Old Mar 26, 2006 | 01:31 AM
150blue's Avatar
150blue
brake pads/warped rotors can also do it, if you or anybody did brakes recently check them again. this happened to my work truck last year.
Old Mar 26, 2006 | 02:18 AM
SpringerPop
So, what happened when you jacked up the front end and checked for play in the bearings. Was one bearing noticably loose?
Pop
Old Apr 19, 2006 | 02:31 AM
79shovelhead
Left front didnt wiggle but spun the wheels and the bearing sounded dry. Changed out the hub and problem solved. I bought two so I am gonna change the right side too. It probably isnt far behind
AndeyHall
Jul 5, 2011 05:53 PM
F 250 6 liter
May 28, 2010 08:42 AM
GreatWhite99
34
Sep 30, 2009 08:34 AM
UP_There
Oct 24, 2007 07:52 PM
JimNolan
Jun 19, 2006 03:57 PM
