Carb Problems
Old Mar 22, 2006 | 09:55 PM
customcab66's Avatar
customcab66
Carb Problems
My 66 Custom cab truck had a 352 in it with only 40k on it and it broke the crank. I put a fresh rebuilt 390 in its place and for some reason my carb will not idle the truck in gear without the choke being set slightly. Took another carb off a 428 and now the truck runs perfect. The first carb ran the 352 great but it don't like the 390. dose anyone know what size jets I should run for a 4bbl 600cfm Holley carb? Thank you for your help.
Old Mar 22, 2006 | 10:26 PM
fordraceboy's Avatar
fordraceboy
whats your altitude? i'm at about 500 ft or so and run 78's in the primary's and fidled with the secondary spring for a while to get it right....
Old Mar 22, 2006 | 11:14 PM
customcab66
the altitude here is about 2500 ft or so.
Old Mar 23, 2006 | 01:06 AM
Bear 45/70's Avatar
Bear 45/70
You needed to enrichen the idle circuit by either turning out the idle screws or raising the float level. Pulling the choke on enrichens the idle mixture. A 390 need more fuel to feed the engine at idle than a 352. The main jets have noting to do with idle circuit as long as they are not plugged.
Old Mar 23, 2006 | 11:35 PM
customcab66
Took the carb apart pulled the metorign block out found a bug in it, not sure what is wrong with the carb yet, but I am sure it is not some thing wrong with the motor. Have a loaner carb and the motors runs perfect.
Old Mar 31, 2006 | 11:57 AM
customcab66
Thank you for all of your help. It was a bug in the carb that had gotten in while it was off the truck. Now the truck runs like a champ.
