Autolite carb rebuild kit source?
Old Mar 22, 2006 | 08:43 PM
firstford's Avatar
firstford
I just purchased a 1970 F250 dually flatbed from the local fire department. It only has 39,000 miles on it and has only had 1,000 miles put on it in the past 18 years. It has been stored inside the entire time and everything works great except for the carb which is leaking -- to be expected. (It still runs, it just tries to stall when you give it gas. It has to be floored from a standstill.) I'd like to rebuild the existing carb since everything is factory. How hard is it going to be to rebuild the carb, and will Checker likely have the kit? (I've only rebuilt SU carburators on my British cars. Three years ago I didn't own any American cars. Now I own an Excursion, the 1970 Race Truck and a Jaguar with a Supercharged and fuel injected Ford 302. Went from 8 cylinders total in the garage to 26.
Old Mar 22, 2006 | 09:07 PM
eedvark's Avatar
eedvark
You don't say if it is a 2 or 4 barrel but the Autolite 2100 is a simple carb to rebuild .The 4300 can be a bit tempermental and is not nearly as easy to tune as the 2100 .
Old Mar 22, 2006 | 10:30 PM
firstford's Avatar
firstford
It's a 2 barrel.
Old Mar 22, 2006 | 10:33 PM
eedvark's Avatar
eedvark
If you can rebuild a British carb you are home free the Autolite 2 bbl ias the simplest carb in the world.
Old Mar 22, 2006 | 10:40 PM
firstford's Avatar
firstford
Sweet. I took it off the truck tonight and it looks quite simple. I think that will be my weekend project.
Old Mar 24, 2006 | 07:26 AM
BlueOvalBoy's Avatar
BlueOvalBoy
I always had luck with holley jets and power valve in that 2100.
Good luck
Old Mar 24, 2006 | 07:57 AM
Chevy_Eater's Avatar
Chevy_Eater
Just about everybody carries a kit for that carb. Usually under $20.
Old Mar 24, 2006 | 09:30 AM
firstford's Avatar
firstford
I found it at Checker yesterday for $14 -- in stock! It took all of an hour from start to finish to remove, rebuild and re-install it. What a difference! Now I just need to adjust the carb a little as it stumbles a tiny bit in the high revs.
Old Mar 24, 2006 | 11:23 AM
eedvark's Avatar
eedvark
I usually start at 1 1/2 turns on the idle/air bleed screws and go from there. Accelerater pumps can be a problem in those carbs ,I have had some trouble with the little diaphram tearing on occasion. Those carbs turn up on alot of AMCs also.
Cory281
30
Jun 18, 2013 02:17 PM
bulletsneverlie
Mar 28, 2009 08:54 AM
Truckboy
16
Jun 27, 2007 04:10 PM
ClydeSDale
38
Jun 4, 2007 08:56 PM
Troy77+79
Jan 27, 2007 03:17 AM
