What gears do I have???
Old Mar 24, 2006 | 10:39 AM
Big Blue Bertha's Avatar
Big Blue Bertha
I hvae a 1970 1 ton and teh build sheet has D604 in the box for the rear axel. How can I tell what gear is in it? The tag is not on the axel.
Old Mar 24, 2006 | 11:18 AM
67Pustomp's Avatar
67Pustomp
the old school way is to put the tires in the air, put the yoke at 12 o'clock, put a chalk mark to match up with on housing, spin tire 1 full revolution and count the number of times the yoke rotates full circle..crude but effective..a small amount of estimation may be required but you can get it pretty close to what it can only be factorywise..use the rim edge as tire size may effect 1 full revolution..if the yoke goes exactly 3 1/2 times then the ratio is 3.50..a little less 3.40 a little over 3 times 3.20..you get the idea
Old Mar 24, 2006 | 03:36 PM
4Cammer72's Avatar
4Cammer72
on the right axle tube facing back of the truck, next to the center section it should be stamped in the tube.
Old Mar 24, 2006 | 06:52 PM
1972FordCustom's Avatar
1972FordCustom
the only problem w/ that is if somebody has changed the gears, unless you bought it new.....
Old Mar 24, 2006 | 07:07 PM
brian_06328's Avatar
brian_06328
I checked the ratio in my old BII by taking my RPM at 55 mph in 4th gear (1:1) as well as my tire size to a website that had a calculator
http://www.ringpinion.com/content/ca...rs/default.asp
and punched in what I knew and it spit out the gear ratio. The bad thing about that is that it's not terribly precise, but I was only curious and so it worked fine to get me the ballpark.
Old Mar 24, 2006 | 07:37 PM
4Cammer72's Avatar
4Cammer72
or in my case where it has a jag rear
