Lowering truck ?
Old Mar 22, 2006 | 02:08 PM
sbilbrey's Avatar
sbilbrey
I have a 1977 f100 that I would like to lower some. I am thinking of cutting a coil and a half out of the front and using lowering blocks in the rear. However, this is a truck that is used as a truck - a load of mulch here, an engine block there, nothing real heavy. But I do want to be able to continue using it this way. Recommendations?
Thanks,
Sammer
Old Mar 22, 2006 | 02:24 PM
jsutton's Avatar
jsutton
I think we have done just about ruined GF2501 thread and original post about smaller tires with talk of paint, wheel spacers, and lowering.
But Sbilbrey if do a search on here for lowering you'll get a lot of threads.
Jason
77 f100
Old Mar 22, 2006 | 03:12 PM
75BigBlock's Avatar
75BigBlock
i have a 75 F-150 4x2 that hasn't been lowered.. yet. I have 15 inch rims (same size as stock) but put on 265/50R15 on it all the way around. it looks alright, but when i drop it with some drop beams and some shackles and hangers, it'll look a lot better. I'm gonna get bigger rims and put taller tires in back, but keep about the same height tire in front. the guy at the tire store when i got these a few years back suggested 295/50R15 on the back and said that he's had guys with older camaros use that setup.. but this isn't a camaro and I really don't like the look of tires sticking out past the fenders. but that's just me. the 265's being 50 series bring the sidewalls right to the edge of the fender. check out my gallery if you want a peek at it. I think I've got some newer pics anyway. there's my 2 cents
Old Mar 22, 2006 | 04:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
Lowering question split to it's own thread.
Old Mar 22, 2006 | 05:03 PM
chet_cowan's Avatar
chet_cowan
If you cut coils in the front you will have major camber issues. 1/2 a coil you may be able to get away with but 1.5 coils will be def. problems. Drop beams are the way
Old Mar 23, 2006 | 06:14 PM
move's Avatar
move
I use to see DJM advetise drop beams but I don't no more. Where can you find drop beams at?
Old Mar 23, 2006 | 10:49 PM
trinogt's Avatar
trinogt
I just saw them there not too long ago...
http://www.djmsuspension.com/Product...5F100Parts.htm
Mark
