Carb Question for 360
Old Mar 22, 2006 | 04:31 PM
comochja's Avatar
comochja
I have a 76 360, bored .040 with a mild cam thats supposed to be for torque(sorry, don't know any lift numbers). It has a 4V intake, but I was running a 2V carb until recently. The Holley I sent to be built was too warped to seal up, so I must purchase a new carb. My mechanic (a bow tie man) swears by the Edelbrock carbs, but in this forum, I see most Ford builders prefer Holleys. The truck (66 F100) will only be used for cruising, no towing.
Which carb should I buy that would work best right out of the box?
I am using my header money, so it will have stock exhaust for the near future. Any help appreciated.
Old Mar 22, 2006 | 04:41 PM
fordraceboy's Avatar
fordraceboy
it's pretty much all personal preference when it comes right down to it.. holleys are a bit more performance oriented (read finicky), but the edelbrocks are a bolt it on and forget about it affair in my past experiences.. stay around 600 cfm and you'll be golden.
Old Mar 22, 2006 | 04:51 PM
comochja's Avatar
comochja
Bolt on and forget it, thats what I need. Thanks
Old Mar 22, 2006 | 05:53 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
You sure can't beat the Holley 570 Street Avenger for your application they're wet flow checked / tested and work great right out of the box. Holley and dirt don't get along so be sure to have a inline fuel filter. No metering rods to wear or replace in Holley vs Edelbrock carbs but then again I have run one Holley over 650K miles without any problems. You should of chimed in back in December as I threw away 17 carbs, only 3 were Holley.
.....=o&o>.....
Old Mar 22, 2006 | 08:30 PM
eveready77's Avatar
eveready77
If you go with a holley it would be a good idea to check in summit, they sell a little insert that is supposed to save your powervalve in the event of a backfire.
Old Mar 22, 2006 | 08:39 PM
Bear 45/70's Avatar
Bear 45/70
All the new Holleys are backfire protected. Only the old ones need the power valve protector kit.
Old Mar 22, 2006 | 09:23 PM
"Beemer Nut"
That power valve protector has been around about 10 years.
Be sure if you get a Holley for Ford that has kick down linkage if your running auto trans as well order one with electric choke. After the choke, fast idle and idle mix are set you'll be surprised how well mannered your motor will run.
.....=o&o>.....
Old Mar 22, 2006 | 09:48 PM
eveready77's Avatar
eveready77
Wow, I guess it's been longer than I thought since I fooled around with Holley carbs. Thanks for the update guys!
Old Mar 23, 2006 | 09:10 AM
comochja's Avatar
comochja
Thanks for all your suggestions. It is an automatic, and I heard that the kickdown had to be modified for an Edelbrock.
