94 Ranger intermitent fault
Old Mar 22, 2006 | 10:19 AM
califhaggis's Avatar
califhaggis
Have a 94 Ranger XLT, 2.3 Lit engine, manual transmission, 2wd with over 190k. For the past few months the engine has been cutting out. This happens when hot or cold, at idle, slow or high speeds. When pulling over shutting off the key and when going to restart, the check engine light does not come on and the vehicle wont start. After sitting for a few minutes or more the check enginge light will come on and the truck will start. Have had it in to the shop and they cannot find the problem or duplicate it. There is no eec codes and the fuel pressure is good.
Need some help on diagnosing the problem can anyone help.
Old Mar 22, 2006 | 10:23 AM
pike_hunter's Avatar
pike_hunter
When it will not restart, do you have spark? Do you have a distributor or coil packs?
Old Mar 22, 2006 | 10:47 AM
califhaggis
Spark is good and it has coil packs
Old Mar 22, 2006 | 11:32 AM
Kijutsu's Avatar
Kijutsu
without a check engine light, the first thing I'd suspect is the computer itself.
Old Mar 22, 2006 | 01:24 PM
pike_hunter
If you have an ECM relay I would try swapping it with one of the others that are not vital to run the truck. If the problem goes away then it is the relay and you need another one. If not I would start by looking at your wiring. Is this truck is fuel injected? Can you verify fuel pressure when it will not start?
Old Mar 22, 2006 | 03:37 PM
87 XLT's Avatar
87 XLT
When it wont start, do the ther idiot lights & fuel gauge work?
If they do the ignition switch should be OK, & like Pike_hunter sez try swapping the main relay.
If it's not sending voltage to the ECM/computer, you will have a no start/no fuel pump prime etc..
Old Mar 22, 2006 | 04:19 PM
Bob Ayers's Avatar
Bob Ayers
It isn't the ECM relay, because he has spark.
Old Mar 22, 2006 | 04:23 PM
AlfredB1979's Avatar
AlfredB1979
Okay, have you tried pulling codes yourself? Every now and then we hear of shops who legitimately don't know what they are doing, so grab your paperclip and Haynes manual and try again.
If you have done nothing to the truck that is detrimental, like pull out the thermostat, I would suggest getting the coils and ICM checked. When they are going bad, the heat affects them more often than not....when thye cool, things work okay for a while.
Otherwise, we are a stuck (or worse) than you are with guesses alone...
Old Mar 23, 2006 | 06:36 AM
pawpaw's Avatar
pawpaw
Are you saying you have spark during the time the CEL is OUT????? If so, as Bob suggested, it's not likely the computer power relay.
If you don't have spark during the time the CEL is out, I'd try the computer power relay swap pike_hunter suggested.
The CEL being out & it not starting, is a good clue, if we can just interpret it right.
If all that checks out & you have a fuel pump power relay, try swapping it for a like one, not needed to run the engine, say maybe the A/C power relay & see if the problem checks up.
Let us know what you find.
