Leaky 99
Old Mar 22, 2006 | 08:55 AM
GIANTOAK555's Avatar
GIANTOAK555
Leaky 99
After a 15 degree nite last month,my son went out and started his truck.5 minutes later i went out and saw fuel dumping out the water drain tube.We shut it down, let it sit for 4-5 hours started it again, it leaked again,but only a couple of drops.Since then no major leaks,but,if the temp drops below 30 we're getting a few drops(2 teaspoons)only at start up. Did that cold nite possibly crack the drain valve, and if so is that valve replaceable.
Thanks Al
Old Mar 22, 2006 | 09:13 AM
empiretc's Avatar
empiretc
Sounds like the orings of the drain valve of the fuel bowl.
Old Mar 22, 2006 | 09:17 AM
GIANTOAK555
Are they replaceable?If so is it a major project.
Old Mar 22, 2006 | 09:26 AM
Medic 66's Avatar
Medic 66
Very possible indeed......
Old Mar 22, 2006 | 09:35 AM
chapguy's Avatar
chapguy
Here's a cut-n-paste of one I found on here and saved it. Hope it helps.
Fuel Bowl Drain Valve O-ring replacement
here's the procedure just incase you need it
O rings are 1/2" od, 1/4" id, and 1/8" thick
Locate that yellow valve handle at the side closest to the firewall. This is the drain valve. Remember how the pieces are oriented for later re-assembly. There are four #20 Torx screws holding the valve to the filter body. remove the four screws. Using a toothpick, pry the two little yellow o-rings out of where they fit. Replace them. Lube the threads on the four screws. Re-assemble and check for leaks. Replace the Powerstroke cover.
sx
Old Mar 22, 2006 | 09:38 AM
GIANTOAK555
Thanks chap ordering rings right now.
Old Mar 22, 2006 | 09:58 AM
empiretc's Avatar
empiretc
I would recommend getting them from bcdp.
http://www.blackclouddieselperforman...roducts_id=103
They are not a standard size. Even though they do work, for the $10 get the correct ones.
Props to POP with the dancos for a quick fix though.
