Egr, Hmmmmmm!!!!!!
Old Mar 21, 2006 | 02:17 PM
X 03 Jeff's Avatar
X 03 Jeff
Arrow Egr, Hmmmmmm!!!!!!
I find this interesting and confusing !!
I took my truck to the dealer to have the new flash put in. Which they did, but thet also said that they put in a new EGR.
The thing that baffles me is , I have around 33 thousand miles on my truck,
but for about 28 thousand miles or so, I have had my EGR unpluged.
I cant help but to find this odd.
How can a unplugged EGR go bad? And if its unplugged what difference does it make anyway?
Am I missing somthing here?
I like to think Im a logical person, but Im having problems applying logic here.
Unless it was bad before I unplugged it.
Any thoughts??
Thanks for your time
Jeff
Old Mar 21, 2006 | 02:22 PM
bedwards's Avatar
bedwards
If yours is one of the newer models, it probably threw a code but not a cel. just a thought
BE
Old Mar 21, 2006 | 02:46 PM
kw5413's Avatar
kw5413
If it is an '03 as your profile indicates it could be blow-by / residue that is still collecting around the valve or gate. On inspection it could look pretty bad. Plus, you probably coded for the EGR valve.
In addition, it is a universally recognized problem with the 6.0 and many techs may change them out as they would their underware....a matter of customer good will so to speak.
Old Mar 21, 2006 | 03:23 PM
saftman's Avatar
saftman
I read a TSB yesterday that said to fix EGR, EBP, etc. problems to change the parts, not to clean and replace with the same parts. Hope this helps.
Old Mar 21, 2006 | 03:49 PM
EnviroCon's Avatar
EnviroCon
This isn't the old day's where parts were actually inspected to determine if they are good or bad. Now if the computer say's it's, it's bad. Could be that saftman is right and the EGR was replaced under the recall. Or it could be that having your EGR unplugged threw codes and the tech threw a part back at it.
Old Mar 21, 2006 | 04:25 PM
Maxium4x4's Avatar
Maxium4x4
The new EGR your tech installed has a special coating. If your old EGR has been unplugged it still will have soot, so when you plug back in for service it will stick.
Old Mar 21, 2006 | 05:21 PM
obxtuna's Avatar
obxtuna
They also replaced my EGR when I had the latest recall done on my 04. I really hadn't noticed until a couple of tanks after the recall when I went to make sure "The Wart" was disabled. I had mine unplugged since the last time it was replaced about 12K miles prior. I cleared all codes and plugged my "Wart" back in before heading in for the latest and greatest.
I think the others who have responded are correct. Ford may jsut be putting a new EGR in for all who do the "voluntary recall" because it'll be back for an EGR sooner or later.
Old Mar 21, 2006 | 07:15 PM
X 03 Jeff's Avatar
X 03 Jeff
The general concensus here seems to be the same.
Replace it, good or bad.
I guess I have a different mnd set, if its not broke dont fix it.
From what I am understanding it is still a good idea to unplug the EGR ?
Jeff
Old Mar 22, 2006 | 07:52 PM
Jerricho's Avatar
Jerricho
Simply unplugging the EGR valve isn't good enough. There is enough back pressure in the exhaust to push the valve open. It doesn't take much effort to pull the valve open or another way to explain it is there isn't much spring pressure holding it closed. If you have EGT gauges you will really notice the difference after the valve is permenatly sealed, especially after several visual inspections.
Old Mar 22, 2006 | 10:38 PM
X 03 Jeff's Avatar
X 03 Jeff
Jerrico, are you saying it is better to keep the EGR cloesd [sealed], and how would I acheive this if it is a better way?
Jeff
Old Mar 23, 2006 | 09:48 AM
EnviroCon's Avatar
EnviroCon
Jeff- Here's the EGR Disconnect thread. I put it on the page that Jerricho describes the way he sealed his EGR. The whole threads an interesting read, but a little (52 pages) long. Enjoy.
Old Mar 23, 2006 | 11:23 AM
Antacus's Avatar
Antacus
You are assuming the techs change their undies
Old Mar 23, 2006 | 12:52 PM
kw5413's Avatar
kw5413
Or even wear any for that matter...
Old Mar 23, 2006 | 01:33 PM
Diesel Man's Avatar
Diesel Man
I ran my 05 with the EGR unplugged for a while and it almost completely eliminated the turbo lag. However, after a few hundred miles I noticed that, even though the turbo spun up faster initially, it would not build total boost as high. And the famous turbo whisle was replaced by a low drone. So, I plugged it back in and after a few miles it's back like it was. Big turbo lag but turbo boost is improved and turbo whistle is back. Anybody know the technical explanation for all this?
Old Mar 23, 2006 | 05:31 PM
Antacus's Avatar
Antacus
Ohh my, that was a vision I did NOT need as I am headed to dinner, heh.
