Trans doesnt downshift at full throttle.
Old Mar 21, 2006 | 11:55 AM
Tectron1's Avatar
Tectron1
Under full exceleration(floored) my trans(1994 e4od) is failing to fully downshift into the lower gear. Its as if I put it in neutral and floored it. I have only noticed it once since I floor it mayby once or twice a year. But I have had codes 628 and 625 for some time now but the trans works as it should(exept for this instance) Last year I replaced the mlps and I have gone through the wiring several times and all of the external connections are good. I have suspected a tps for the other issues, Would a bad tps cause this condition?
Old Mar 21, 2006 | 05:51 PM
alz's Avatar
alz
If you mean that when you floor the truck and it does not go into passing gear? That sounds like TPS. You say that when you floor it, it's as if it were in neutral. Do you mean it does not accelerate, or it revs up like not in gear?
Old Mar 21, 2006 | 06:14 PM
quicklook2's Avatar
quicklook2
you have checked the level of the trans fluid after it is warm right?
last week someone was having problems and he did not check fluid properly.
have you drained trans and convertor and put in new fluid lately?
Old Mar 21, 2006 | 08:19 PM
vman's Avatar
vman
I know I had that problem when I ripped the wiring off my speed sensor.
Old Mar 23, 2006 | 10:09 AM
Tectron1's Avatar
Tectron1
I checked the fluid and it was about 1/4 pint low, I wouldnt think that would cause it to slip that bad. I dumped the converter and pan about 6 months ago when I swapped in a differant engine, and I change it regularly otherwise(plug in pan).
When I floored it it started to downshift but instead of going into passing gear it acted as if I put in neutral, When I eased up on the pedal it kicked into gear like its supposed to. It downshifts like its supposed to when I dont floor it.
Old Mar 23, 2006 | 10:16 AM
Kemicalburns's Avatar
Kemicalburns
pull the codes. if something is going on it will store something.
Old Mar 23, 2006 | 10:23 AM
quicklook2's Avatar
quicklook2
low is not filled.
fill to proper level.
Old Mar 24, 2006 | 10:11 AM
Tectron1's Avatar
Tectron1
Well I cant get it to do it again so I guess it may have just been a fluke thing, I added 1/4 pint and I guess I'll leave it at that.
LARIAT 85
17
Dec 26, 2020 09:51 PM
LARIAT 85
Sep 7, 2016 01:22 PM
Buck Dharma Fan
Dec 22, 2015 08:55 AM
Greg5OH
101
Nov 2, 2012 03:55 PM
epos48
Jun 3, 2007 06:55 PM
