Sponsored by: Real Truck
help with lift
Old Mar 21, 2006 | 08:34 AM
Crazymxer's Avatar
Crazymxer
help with lift
im putting an 8" lift on my 99 F-250 and need to know what else to buy, the skyjacker kit comes with front and rear leaf's, pitman arm drop and hardware. but do i also need extended brakelines, and driveshafts?
kyle
Old Mar 21, 2006 | 09:35 AM
EnviroCon's Avatar
EnviroCon
Welcome to FTE. I thought the Skyjacker kit came with brakelines and vacuum tubing(ESOF)? If not, you'll need them. As well as a carrier bearing drop kit if you have a 2 piece driveshaft. You may want to consider new driveshafts, get the kit installed and see how bad the vibrations are and check for any binding in the u-joints. You may also want to consider an adjustable trac bar. The box kit comes with a trac bar drop bracket, but you can install the lift and center the front axle a lot easier with the adjustable trac bar. I assume you're also going with larger tires (37"-38"). In which case you may want to upgrade/install a beefier steering stabilizer. The larger wheels will wear out a steering gear box pretty quick. Depending on the overall size of the tires, you may in the future want to consider x-over steering and a ram assist steering set-up. Also check the differential breather tubes to make sure they're not being stretched. Usually you can just relocate them, but any auto parts store carries the tubing and it doesn't cost much. That's about all I can think of off the top of my head. Skyjacker's a good brand, you'll enjoy it. Post back with some pics of the new ride.
