Sponsored by: Real Truck
PSD Tire Sizes
Old Mar 22, 2006 | 01:11 PM
EnviroCon's Avatar
EnviroCon
jt- You're right it can be confussing. A 9" wheel isn't actually 9" wide from outside to outside. The 9" comes from measuring inside the wheel. Look closely at the "Measuring Wheel Offset" diagram on that site and you'll see what I mean. Backspace on the other hand is measured from the outside of the wheel to the back of the hub mounting surface. That's why your number's aren't adding up. I hate the use of offset as a measurement for truck wheels. It may work for people with cars, but it makes it difficult for us to figure things out. Backspacing is easier in helping to figure out if a wheel will fit.
Old Mar 22, 2006 | 01:15 PM
jtharvey's Avatar
jtharvey
Ah Ha!! And another discovery is pointed out to me. Thank you for clearing that one up. It seemed to me that the backspace would be the more important measurement. I also found while serching last night that the backspacing for our SD trucks should be between 4.5" and about 4.7" so the wheels I'm looking at are withing the spec.
jerrymlr1
Jul 31, 2014 09:03 PM
bboone52
Oct 5, 2006 01:44 PM
Dr.Z06
Feb 14, 2005 10:17 PM
rockfiv0
Oct 31, 2002 09:51 AM
