I topped mine at 93.00, second most expensive fillup, one last summer tripped 101.35 when it clicked off. have a feeling this summer is really going to suck the wallet down.
Yeah. I'm not looking forward to it. I got close to the big one once last summer, coming in at about $98.00. Luckily, we were on a road trip and it wasn't my turn to pay for the fuel.
Don't feel too bad, I have a motorhome that holds 90 gallons! The last time I tried to fill it up had to reset the pump 3 times and then my credit card company put it on hold thinking someone had stolen my card and was filling everybody up at the gas station!
Cangim
can you give me a parts list for the hutch mod? and where did you buy your parts?
I was going to get the kit from diesel manor but cant find it on there web sit anymore.
Cangim
thanks
Keith
All you need is some 3/8 Stainless Steel tubing (6 in is more than enough), a 3/8 SS union, 5/16 SS tubing (6 in or so doesn't really matter), 5/16 union. 5/16 rubber fuel line (24 in is more than enough), 5/16 hose clamps, and some time to do it. The number of clamps will depend on if you run a pre filter and if you want to put two clamps on the frame fuel line. I used two there as there isn't any type of barb. In short drop the tank, take the sender out. Measure distance from top to bottom, youll need it to get the length of the tubing. There is a white fuel mixer thing, take it off, put union on, attach tubing, cut to proper length with black pre screen. Drill out pre screen, slide pre screen on. Here is a link from one of the originators I beleive http://community.webshots.com/album/32614313yLKyrS
Cangim that link is to the guy that I copied when I did my tank.
Username Hutchinaugusta, hence the name "Hutch" mod.
And Luvemhot you'll be very satisified with the improvement after you are done.
