engine swap, 240 to 352?
Old Jan 10, 2003 | 09:22 PM
JIM EB's Avatar
JIM EB
I have a 1970 f 100 4x4 with a 240 6 and a 4 speed.
Every Manual Transmission has a Low gear
I just bought a 1975 ford with a 352 or 360 or 390.the v8 is not the orignal motor.
It does say 65, 352 below the front of the drivers side head.
The man I bought it from thought it was a 360.
I need to know where the ID numbers on the engine are.
I also want to put this in my 1970 f100 4x4.
will it bolt to my 1970 4 speed trans?
thanks,
Jim
[font color=blue]Jim,Welcome to FTE!
The Upper case has been edited out by Administration,Please refrain from its Use.
As you can see FTE Users don't like it when it's used,
[/font]
Old Jan 11, 2003 | 05:18 AM
jowilker's Avatar
jowilker
Hoss, typing with the caps on is considered shouting, and I don't like being hollered at, so STOP IT.
The FE will bolt to the same engine perches, but the tranny bells are different. If both are str. drv. swap the engine with bell attached to the tranny.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member 0004 since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Jan 11, 2003 | 09:50 PM
snow's Avatar
snow
>IT HAS A 240 6 AND A 4 SPEED
GRANNY LOW <> This Wacky Term only means 1st gear,all Manuals have them
1st gear is commonly refered to as the Granny gear because you drive slow in it (like grannies do on Sunday).
A 240 engine. *sigh* You should be so lucky to have even that. My engine just died. (See my post "*sigh* Not a good day today." Rest in piece you wonderful engine that was so good to me.
Old Jan 12, 2003 | 11:31 AM
JIM EB's Avatar
JIM EB
JIM Sorry about shouting.I didnt realize that i was. The doner v8 truck has a 3 speed automatic trans in it. We,ll have to find a bellhousing for the 4 speed then.I didnt know that all the 4 speeds had the granny gear.Does that number 65 right above the 352 on the block mean that i have a 1965 motor?I put new main bearings and seals in the 240 last year.It doesnt leak oil but it does smoke some.I do want to pull heavy trailer with it.Would i be better off with rebuilding the 240 or putting in the v8?
Old Jan 12, 2003 | 02:45 PM
Rogue427's Avatar
Rogue427
A 65 FE 352,360,390,427, would be a C5 for 65 C5 =1965 C6=1966 Just gussin it would most likly be a 390 but the only way to tell forsure is to check bore + stroke.
Old Jan 12, 2003 | 03:24 PM
FE427TP's Avatar
FE427TP
This should be changed to read that sometimes the FE will bolt to the same engine perches. mine did not when I swapped from a 240 to a 360, it changed where the engine sat significantly enough that I needed to swap to the perches designed for a FE
Old Jan 14, 2003 | 01:35 PM
JIM EB's Avatar
JIM EB
JIM Thanks for the information and the picture.I think im gonna put the v8 in.I have them both in the pole barn but its so cold out there.I may wait till it warms up.If i have to change the engine perches i would have them in the doner truck.I will just have to find a bellhousing.
Old Jan 14, 2003 | 01:44 PM
JIM EB's Avatar
JIM EB
JIM I just recently found this site and have learned alot.Thanks again for the information, and now i need to get out there and get to it.
Old Jan 14, 2003 | 06:12 PM
1968F250LWB's Avatar
1968F250LWB
