Hello guys and gals,
I have been posting over at the f150 big boy section, never got anytime to spend with all of you!
I have a question about 97 explorer interchange parts.
What year or years are common for the following parts:
1. Instrument cluster clear plastic.
2. Steering column housing/shaft.
3. iginition bezel (black plastic around iginition key part).
4. Right and Left cruize control buttons.
Like for example, could I use the same steering column from a 92 Explorer for my 1997 Explorer?
What year did Ford change up the parts for the explorers? (I would guess starting at 1998 for the new style, correct?)
I apprieciate all your help and answers!
Thanks,
TONY Z.
#40
PS. Only reason I ask is because, I could get these parts at a salvage yard, instead of the dealer. Only thing is, there is not too many 1997's laying around.
Thanks again,
TONY Z.
#40
Not sure exactly what is interchangible within the ranges but 91 - 95 is Generation 1 Explorers, 96 to either 01 ir 02 is Generation 2 Explorers, and 02 or 03 & up are Gen 3. Within a generation may interchange, but probably not from generation 1 to 2, etc. All that being said, almost all salvage yards have access to cross reference sheets that show what parts interchange on what cars/trucks.
