Power Window Motor???
Old Mar 20, 2006 | 02:42 PM
mirroman's Avatar
mirroman
How in the hang do you get to it to replace it? I have removed the panel and the plastic but can't for the life of me figure out how to reach it...
Old Mar 20, 2006 | 04:11 PM
95X15's Avatar
95X15
You can reach thru the access holes to reach the motor - to remove it, you have to find the dimples in the panel metal that line up with the rivets that hold the motor and window regulator in the door, drill a hole to access the rivets to drill them out. Suggest searching for window regulator removal and follow procedure - it may be in Haynes manual also. Be careful since once all three rivets are out the whole motor, regulator and window will move and can get your hand
Old Mar 20, 2006 | 04:53 PM
GWall's Avatar
GWall
I have changed them on a 1985 and a 1994. The motors were held in with hex head screws that required a 5/16 socket rather than rivets. Either way you still have to drill out the dimples. Are you sure you need to replace the motor or just the plastic gears. They are notorious for failing on these trucks.
Old Mar 21, 2006 | 08:29 AM
mirroman's Avatar
mirroman
Good point. The motor is turning so it probably is the gear. But I still have to get to it first. Thanks.
