1966 - 1977 Early Broncos
302 rebuild
Old Mar 20, 2006 | 10:50 AM
earlybroncoboy's Avatar
earlybroncoboy
Thumbs up 302 rebuild
I just started my engine rebiuld this weekend. I took the manifolds off, took the plug wires off, and took the valve covers off. Today I'm taking the heads and intake manifold offand more. Wish me luck I will need it It is my 1st rebiuld considering I'm 14. I'm sure I'll have many Q's !!!!!!!
Old Mar 20, 2006 | 09:06 PM
bronco69's Avatar
bronco69
have fun my first was on a 302 two ,when i was 13, lol but that engine ended up blowing apart when my frount pig slamed thought the oil pan. So now im runnig a 400+ HP 351 ceveland cobra jet.
Old Apr 21, 2006 | 05:26 AM
dk5122's Avatar
dk5122
Get any where yet with the rebuild? Please tell..
Old Apr 21, 2006 | 09:14 AM
33boggers's Avatar
33boggers
Yeah DK you need all the motor advice you can get
Old Apr 22, 2006 | 09:51 PM
33boggers's Avatar
33boggers
Last I heard you wanted to build a 351. Or is that just a boat ancor in you garage or are you just to busy trying to put in a nw shtter in your house? You know the old saying sht or get off the board.
Old Apr 24, 2006 | 12:33 AM
dk5122's Avatar
dk5122
Sean YOU SHOULD BEHAVE ON HERE!!!!!!! TY
P.S. Worry about your own truck...
Old Apr 28, 2006 | 10:49 AM
earlybroncoboy
Yes I did I tore it down, I ordered the new rings and bearings and waiting on them. I'll let you know how it works out,
sorry so long on repley
Old Apr 28, 2006 | 11:04 AM
dk5122's Avatar
dk5122
Cool Thanks..
Old May 9, 2006 | 08:18 AM
earlybroncoboy
Thumbs down Problems
I got my parts and I tore the crankshaft out. As I was doing so I discovered one of these broken. Do any of you know were I can get one?????????
Old May 13, 2006 | 12:06 PM
RCrawler's Avatar
RCrawler
Check with a machine shop and see if they have any salvage blocks or parts laying around. If you find another one, you will need to have the block align bored because those caps are machined to the engine they came from.
Jason
Old May 23, 2006 | 10:47 AM
earlybroncoboy
I'm still not sure what to do? I found an 84 302 but the parts arn't interchangable. And I def. don't feel like converting to EFI??????
Old May 24, 2006 | 02:20 PM
RCrawler's Avatar
RCrawler
What isn't interchangeable? The crankshaft balance is different between the early and the late model 302's, but you should be able to use the '84 blocks main cap.
Jason
Old May 31, 2006 | 11:21 AM
earlybroncoboy
The 68 302 is a 289 block bored out to a 302!!! atleast I'm pretty sure?????
Old Jun 27, 2006 | 09:04 AM
earlybroncoboy
Smile motor
I'm getting ready to order a crate motor I'll let you guys Know How I make Out.
Old Jun 30, 2006 | 01:08 PM
Huntersbo's Avatar
Huntersbo
My buddy bought a couple of junk yard motors for his mustang and bronco and they both worked great. the one in the bronco is a 1992 mustang 5.0Ho he got for $220 and it still turned over and had good compression so it ran. That is a stout bronco and his mustang is a strong runner too. Both stock mustang rollers.
but it is a gamble. Any 80s 302 or 351 should be good with out the egr, rv cam, 87$ summit headers, and if you are really ambitious a port and polish job of the carburater and intake through the heads with 1.94"/ 1.6" valves. I think that those motors all came with 8:1-8.5:1 compression which is good for 87 octane.
I think you could build one of these motors for 900$+ any labor.
