Daytime Running Lights!!!!
Old Mar 19, 2006 | 05:57 PM
ExpeditionNutt's Avatar
ExpeditionNutt
hey all.... can anyone please tell me how to disengage the DRL on my '03 expy? sometimes they are a blessing.... other times like " high noon " i don't cre for them.... i see other expys without them on...maybe they are just newer than mine. thanks,
anthony
Old Mar 20, 2006 | 10:46 AM
pitrow's Avatar
pitrow
if you figure it out, let me know too.
Old Mar 20, 2006 | 10:54 AM
hallam's Avatar
hallam
Pull the fuse...
Note sure about the 03s... I have a 97 and I disabled the DRL by pulling the fuse for it under the hood. 30 amp I believe.
I would think you would be able to do the same thing.
Old Mar 20, 2006 | 11:57 AM
pitrow's Avatar
pitrow
Does that fuse affect other circuits? I remember looking at the fuse block for my '99 and I thought the fuse for the DRL also ran something else.
Old Mar 20, 2006 | 12:38 PM
Onespeed24's Avatar
Onespeed24
I guess my '03 XLT didn't come with DRL's. I have a three-way switch that has automatic-off-on. The automatics are light sensing I guess, but I never use them.
Was the DRL standard in later builds?
Old Mar 20, 2006 | 12:47 PM
hallam's Avatar
hallam
Pull the fuse...
Not for the '97. When the DRL module failed on my truck the headlights remained on, even with the truck off. Pulling the DRL fuse was the only way to bypass the DRL, turn off the headlights, and save the battery.
The headlights still work manually. I've never bothered to replace the DRL module and have never had any problems with other circuits.
Things could be different for other model years...
Old Mar 21, 2006 | 12:26 AM
timcpa's Avatar
timcpa
I have an 06 and it is not standard equip. I don't remember it being ofered as an option.
Old Mar 21, 2006 | 11:19 AM
pitrow's Avatar
pitrow
I think only certain years had the DRLs. My '99 Expy has 'em, but my roommates '01 (or is it 02?) f150 doesn't.
Old Mar 21, 2006 | 05:23 PM
hallam's Avatar
hallam
Pull the fuse...
I think it might depend on the vehicle regulations where you live.
Didn't think of it before, but I'm from Canada were DRLs are mandatory equipment - on every vehicle. That might explain the "I have 'em" "I don't have em" situation...
Old Mar 21, 2006 | 06:45 PM
pitrow's Avatar
pitrow
oh yeah.... I just had mine expy worked on at the dealer last week and he said "did you know this is a Canadian unit?" I wasn't aware of that until then, so maybe that is the difference.
Old Mar 21, 2006 | 07:39 PM
MarkysExpy's Avatar
MarkysExpy
Doesn't the switch pull out or push in on the '03s to engage or disengage????
Old Mar 21, 2006 | 10:20 PM
ExpeditionNutt
DRL's
thanks fellas.... i think i'm stuck with them 'cause my expy is a canadian model... ohh by the way, would that explain why mine didn't come with the EXPEDITION badging on it.... not really complaining because it looks good without them and no problem to wax... thanks again
Old Mar 22, 2006 | 05:53 AM
Loggy's Avatar
Loggy
I have a 06, had a toggle switch installed in the circuit and mounted above the brake release.
Now shutting down the seatbelt chime is another issue.... I am going to need a wiring diagram for sure!
Tim --->>>
