I have an '84 E-150 witha 351w, it runs great but it has started blowing oil back through the dip stick tube and the oil fill tube. I took most peoples advise, one side it was too much back presure caused by clogged cats, so I did away with the cats and installed dual exhaust. Another person said my oil return lines in the heads were clogged. so I pulled both valve covers and run a brush through the oil return holes. My pvc valve mounted in the pass side valve cover is working great. I also pulled all 8 plugs to see if maybe I had a broke ring on a piston, all 8 were in great condition, dry with a light ting of brown on the insulators. I have become flustered over this! Does anyone have any ideas with this problem??? It really starts blowing oil out real bad around 45-50 mph.
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
