FE starters all the same?
Old Mar 19, 2006 | 03:08 PM
64F260's Avatar
64F260
Can the starters interchange among different engine displacements and years, and automatic vs standard? while we are at it, will FE starters interchange with any other Ford V8, such as the 385 series, 302/351, etc Thanks
Old Mar 19, 2006 | 03:48 PM
fordraceboy's Avatar
fordraceboy
all FE's take the same starter... and to the best of my knowledge, they only fit the FE's.
Old Mar 19, 2006 | 04:35 PM
64F260's Avatar
64F260
I just saw a starter go for $103.00 on ebay, just curious why. item #8046556490. Could it be for the proper build date for a restoration?
Old Mar 19, 2006 | 08:41 PM
customcab66's Avatar
customcab66
I got a starter for a 289 in a 390, just had to cg\hange the nose cone.
Old Mar 20, 2006 | 01:43 AM
Bear 45/70's Avatar
Bear 45/70
There are two different starter. Early FE's had a different count for teeth on the flywheel than later ones did. So there are two different bendix' on starters with different tooth counts. The starters bolt up the same but make one he!! of a noise when you crank them with the wrong number of teeth
Old Mar 20, 2006 | 05:02 AM
ford390gashog's Avatar
ford390gashog
Deleted...
Old Mar 20, 2006 | 05:29 PM
64F260's Avatar
64F260
Do you know when the change took place on the starters?
Yeah, that guy on ebay really wanted that starter! It didn't look very new, either.
Old Mar 20, 2006 | 06:40 PM
bertha66's Avatar
bertha66
I think that the change came about 1965, a least for the Galaxies, my 64 Galaxie used the old stile and when I put in a 66 Fairlane engine it had the newer type.
Old Mar 20, 2006 | 10:00 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I concur !!! We've had this discussion before
I don't know if I had the wrong one in a box, but I used an Arco Marine starter for a 460, or so I thought. Now, I wonder if it was for a Marine 427.
But it had the right tooth count and three-bolt pattern and worked like a charm for a long, LONG time...
john jamieson
Jul 9, 2018 08:50 PM
Björn
Aug 19, 2016 11:18 AM
classic ford guy
16
Jan 21, 2012 05:40 PM
Brad Deicke
Aug 21, 2002 03:28 PM
