Euro tail lights
Your tail lights should be the same as an F150 uses, and I know in some countries the lamps themselves are available with the yellow sigs. Once you get the lights...I can help. You will also need a pair of single filament tail light sockets.
First of all, there is a green wire along the top of the steering column (if your wiring matches that of an Excursion) by the hazard lights switch. This needs to be cut as this feeds the brake lights...without messing with the trailer brake controller, high mount stoplight, etc. This green wire only feeds the brake lights in the tail lights.
In the rear, cut the "major" side of the existing brake light-turn signal circuit. This wire should now be attached to the new amber turn signal socket. You will then need to ground the negative side of the amber turn signal socket. Turn sigs are done.
You then need to run a new brake feed from the high mount stop light to the tail lights. Connect this to the "major" side of the stop light-parking light circuit. (The one you cut off at the back.) You now have red brake lights and parking lights.
I wired mine (thanks to the help of CHPMustang) in this fashion. If you need any more help, please feel free to PM.
A fella named bjornar from Norway posted about this about 5 years ago...
Try placing AMBER bulbs where your stock reverse lights are, behind the clear part of your stock taillight housing. Just replace the white bulb with an AMBER one, and then cut the reverse light wires running to it and run wires from the turn signal to it, instead.
You'll have to mount some aux. backup lights since your backup lights will be gone, now... but you'd want to do that anyway, right!?
Hope this helps,
Tom
If a SD is wired the way an Ex is, the brake light feed and turn sig feed are both on the major side of the lamp. Meaning, if you move the turn sigs with the factory wiring, you'll also move the brake lights.....and have amber stop and turn signals.
Now, if indeed the stop lights are a seperate bulb from the turn sigs...it's possible to just move 'em. Otherwise, you'll wind up with amber stop lights too.
