hi guys, another newbie with a gear question. i have a 90 model superduty with a z5 trans,7.3idi,& this is off the tag on the rear end,5.13 E9TA PA 605400-2. any idea what i have? thanks for any reply.
Hey Dave, thanks for the reply. I just use the truck mostly on weekends, I have a work truck for everyday. I may use it to pull a 16 ft. trailer once or twice a month to haul two or three ATV's.
Hey cookie88,This thing does have dual rear wheels with 10 hole lugs, & 14,500 gvw. Do I need to look for more tags on the rear end, to find out what it is?
thanks 84, thats what I was wanting to know.I guess I didnt ask the right question. Sorry. Any ideas on what gear to change to to get a hiway speed with a lot less rpm,s?
jack up your truck one rear wheel have someone count the turns on the drive shaft while you turn the wheel 20 turns if it is a 5.13 the driveshaft will turn 53 times
I don't know what gears are available for the D80, but the 4.10 or 4.56's you mentioned earlier will give you more top end at a lower RPM. You wold be sacrificing some low end grunt, but no more than you work the truck you won't miss it.
