Building a Computer
Old Mar 18, 2006 | 09:49 AM
preppypyro's Avatar
preppypyro
Building a Computer
Hey guys, is there anyone around that knows exactly how to build a computer? I am building one for the first time and just need to ask some complete newbie building questions, thanks!
Old Mar 18, 2006 | 10:12 AM
Snake1979's Avatar
Snake1979
What are you using the pc for? Gaming, surfing, or buisness? Or a combination of all three, thats the first question we will need answered.
Old Mar 18, 2006 | 10:22 AM
preppypyro's Avatar
preppypyro
It is kind of an all around computer, I bought everything for it allreaddy, just have a few weird kind of questions about installing the motherboard! Seems like my motherboard has 9 screw holes for it, and my case has 6 risers, So I was just curious do I need to go buy three more risers to mount the motherboard on, or will it be fine with just the 6.
Old Mar 18, 2006 | 10:44 AM
Bob Ayers's Avatar
Bob Ayers
With the cost of OS, and with the cost dropping on computers, consider buying a computer from Dell or Lenovo (IBM).
Old Mar 18, 2006 | 10:57 AM
CAFordDude's Avatar
CAFordDude
It will probably be just fine with 6 as long as the whole board is supported.
I've built a few computers in my time but it was a number of years ago. I no longer have the paitence or desire to try and get all the individual parts working. And like Bob Ayers said, it is worthconsidering a pre-fab. If you still want to build one for the fun of it you might want to try a website like:
www.devhardware.com/forums or
www.bestcomputerbuilders.com/forum
They might be able to help you out a little better.
Old Mar 18, 2006 | 11:24 AM
preppypyro's Avatar
preppypyro
Ok perfect, Now does a guy have to put anything behind the motherboard, where it connects to the case? Like washers or some sort? In my kit it came with washer but I assumed they go under the screw, between the head of the screw and the mobo.
Old Mar 18, 2006 | 12:28 PM
jake00's Avatar
jake00
Thats where I put mine, I've built a few pc's
Old Mar 18, 2006 | 12:55 PM
surewhynot's Avatar
surewhynot
Just be sure that the mobo isn't grounding out on the case. I had that happen on my first build. The guys n gals in the forums at www.pcmech.com helped me out alot.
Old Mar 18, 2006 | 01:10 PM
furball69's Avatar
furball69
If you aren't using all the risers for the mobo mounting holes, be careful when plugging stuff in, if there isn't support, the mobo could potentially break.
make sure there is nothing behind the mobo then you put it in; (screws, etc. - whistles).
Make sure the CPU is in the mobo BEFORE the power supply is plugged in to AC, that way there will be no chance to turn it on without a CPU in the board - resulting in a dead mobo. (whistles)
Old Mar 18, 2006 | 02:50 PM
Mil1ion's Avatar
Mil1ion
Most MB's come with installation instructions in the manual.
What motherboard is it Peppy ?
Old Mar 18, 2006 | 04:34 PM
preppypyro's Avatar
preppypyro
I got the asus p5nd2-sli Mobo. Got er all together, just not quite sure I have all the fans hooked up right, or the front panel stuff hooked in the right slots!
Old Mar 18, 2006 | 04:59 PM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
just refer to your motherboard manual for help. The USB order should be red, white/yellow, green, then black. I've done this a thousand times, so send me a PM if you need anything at all.
Ryan
cjben
13
Jan 27, 2009 08:02 PM
Ryan50hrl
45
May 3, 2008 11:28 PM
Andysutt
29
Aug 6, 2004 08:23 AM
Mike W
Jun 16, 2004 02:05 PM
couleeman
28
Feb 11, 2004 11:45 PM
