Sponsored by: Real Truck
More brake issues
Old Mar 18, 2006 | 09:28 AM
superpony18's Avatar
superpony18
More brake issues
I have been trying to track down ny brake problems. I have gone through 2 sets of pads on the front and the rear still looks new. I bled my brakes and do have fluid flowing at the rear. Any suggestions?
Old Mar 18, 2006 | 11:05 AM
biz4two's Avatar
biz4two
What brand of brakes (rotors and pads) are you using? This has a really huge factor as to how quickly the pads are wearing.
I would suggest trying HAWK HPS or even the HAWK SuperDuty line for your needs.
Satisfied has great brakes too.
Currently on my SD...I am running the Power Slot rotors and HAWK HPS with NO problems. They do have a lot better braking power too...which equal shorter stopping distances.
Good luck,
biz
_____________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old Mar 18, 2006 | 12:31 PM
99f350sd's Avatar
99f350sd
The front is over 70% more like 80 of your braking so for wear figure it out on the calc.
Dick
Old Mar 18, 2006 | 04:55 PM
superpony18
Going to save up for Power slot rotors and pads. Thank you for all the help.
Old Mar 19, 2006 | 11:11 AM
superpony18
I had to put new pads on yesterday do to the old ones being to worn. When I went for a drive to brake them in all was good, a little pulling to the right. When I got home I put my hand on all the calipers. The back was pretty cool, front right warm, front left could not touch. They are clean and bleed. From what I can see the lines go from the master to the ABS controller and then the brakes. Could my ABS be acting up with out turning on the light.
Old Mar 19, 2006 | 01:32 PM
99f350sd's Avatar
99f350sd
Jack the front up and see if the brakes are dragging. They should drag slightly. not much though...Calipers could have stuck pistons or the pins could use some lube.
Dick
Old Mar 19, 2006 | 01:50 PM
superpony18
New calipers, lubed everything. Pistons are sticking in the front left caliper due to the heat on that side since it is the only brake working fully.
Old Mar 19, 2006 | 02:06 PM
99f350sd's Avatar
99f350sd
Either its a caliper or the master cyl is bad. Very rare for a AL brake unit to cause brakes to stay on..
Dick
