rubber door seals
Old Jan 8, 2001 | 01:16 PM
beratte's Avatar
beratte
rubber door seals
I just installed new door seals from JC Whitney on my 79 F-150 and now I can barely get my doors to close. Has else had this problem? Has anyone adjusted the doors after putting in new seals?
Old Jan 8, 2001 | 04:49 PM
karljay's Avatar
karljay
rubber door seals
This makes sense, the new seal will flatten out over time. I think you can adjust this with the striker bolt or the lock adjustment on the side of the door. I did notice mine was the same way. You'll probably need to adjust again after they flatten out.
Old Jan 8, 2001 | 06:00 PM
stephenw's Avatar
stephenw
rubber door seals
Ditto on Karljay's info. My passenger door is still a bit more trouble to close than driver's side, suspect because it doesn't get massaged as often. But enjoy the decrease in wind noise, quite remarkable in my old beastie. :-)
Old Jan 8, 2001 | 07:25 PM
classyfish's Avatar
classyfish
rubber door seals
I had to adjust the hinges themselves.
Kevin
Still alotatrucks
ecarter50's Avatar
ecarter50
rubber door seals
